| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 5th 2018, 7:14 pm | |
| - Crazy_Carl wrote:
- I bet you're planning on filling in the factory headlights, building a custom bumper and mounting those LED lights on it.
I am still going to put lights in the original location too. - RichieRichOverdrive wrote:
- Lights look sweet! I should really get myself some of those nilight LEDs sometime, supposedly they're really good.
I have a 7 inch on the hood of my mower. It's awesome. If it wasn't for neighbors, I could mow anytime day or night with that thing. - muckmudd wrote:
- do they have free shipping to Canada?
I do not think so. | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 7th 2018, 8:11 pm | |
| Well got up this morning to a very unusual snow in Oklahoma in April?! It was pretty coming down, lasted a few hours then warmed up to almost 50 later. LOL So I am looking at the dash trying to plan it out as I will not need the throttle cable to my knowledge. I may go ahead for cruise control like my other machine. I have been thinking about replacing the amp meter with a volt meter. I think I have enough holes for everything else I need. Maybe 1 more hole. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 7th 2018, 10:10 pm | |
| I'd rather have an amp meter to show what the battery is drawing from the charging system. Amp meters show that your charging system is working, and can also show if your diodes failed and are letting current pass backwards into your stator(that was a major whoops...put a new diode in and she was fine though). | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
Crazy_Carl Veteran Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 8th 2018, 11:49 am | |
- Huh, one that does both? Well, if you can find one with both readings use it. I'm sure you know that volts and amps are something completely different.
Yeah. My thoughts are items that I add that draw power to watch volts, then amps to make sure I am charging. I have seen a couple round ones that do both, but there are not that many round ones. There are a lot of square ones. - Crazy_Carl wrote:
- Well mighty I’m a voltmeter guy so that gets my vote. What are the four smaller holes in the dash for? Keyswitch, choke, and two light switches?
The bottom left was a switch that went to the rear fender plug. Not sure what it was for. It was an on/off switch not a rocker. One under the square for steering was the light switch. It was a switch to run lights off the light circuit or battery depending on position, next one was choke and the next was switch. I'm thinking I may need to drill 2 holes for what I need. What I am thinking, go ahead with the throttle, then light sw, fog sw, choke, switch. 2 new holes would be left maybe a tether kill, right is my dash fuel shutoff. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 8th 2018, 4:23 pm | |
| No, it will be just an inline shutoff. But instead of dangling on the fuel line by the engine, I have it dash mounted for easy turn off. Like what I had on the sasquatch. You can see that one here on the right. Same exact one. I got 2 of them prepping for my next build. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] April 8th 2018, 8:33 pm | |
| That's a good point since these engines aren't gas hogs like V8s.
Speaking of V8s that shutoff valve reminds me of how race cars are set up. The fuel shutoff has to be clearly labeled and accessible by the driver in a lot of classes. | |
