 [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]
TheCollector
Dave 007
Dave.MTD
22 posters
Go to page : Previous  1 ... 12 ... 20, 21, 22 ... 25 ... 30  Next
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Empty
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 25th 2018, 7:32 pm
Could you post so.e pics of the setup sometime? I am considering doing a twist on my machine.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 25th 2018, 9:33 pm
Great looking lights and foot throttle.  Looks like you used a nice cable for it.
Did you use any teflon tape to seal your oil plug?
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 25th 2018, 11:01 pm
I'm out of pocket till next wednesday. I'll try to get something for you. I might be able to get you a screenshot of the manual till I get a real pic!
Yeah I did the second time. I am beginning to think there may be a crack in the tube out to the elbow on the bottom. I plan on replacing the whole thing soon.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Sig115PROJECTS:
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Sig214[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Sig314
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 25th 2018, 11:13 pm
Here is exactly what it looks like. Need to find my belt guides or make some. Beal Burger
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Belt10
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 25th 2018, 11:15 pm
Cool. Does it have a double clutch or is one just a stationary idler? The clutch in my GT is a double pulley riggins and it works pretty great.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 26th 2018, 4:23 pm
Cool! Thanks for the pic! Defiantly seems a lot simpler than using a RAGB and having more drive train partsm
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 26th 2018, 6:43 pm
Yeah my JD's deck drive was a belt twist, it was pretty neat.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeMay 26th 2018, 10:40 pm
Stock double pulley AK.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 1st 2018, 9:32 am
Now to start getting into gear on this thing.
* Belt Guides (although it has performed well without them.  LOL)
* Wire the winch
* Exhaust (still on the fence for final design)
* Redo the oil drain.
* Make a Battery Cover
* Figure out some storage in the rear?
* Purchase new thrust washers and dust caps for front hubs, then grease them. (Ordered)
* Heims for the steering rod and paint it.
Other nice things to figure out.... some kind of layer to help with hood rub on dash.  Also maybe a tether kill.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 1st 2018, 4:07 pm
So............................
Here it is as of today.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 06011810
I got it out for a preliminary ride today to see what my bugs were.  Boy there was a couple and one monster one.
Simple one... I need another washer in my foot throttle.  It was a bit sticky on the acceleration but not the deceleration.
I do not have video but I took Kal out to the field behind the house.  Suspension is a trip.  Rides smooth through the field bumps even though I do not have suspension in the rear.  The BIG issue is... I need to move the front axle forward at least 4 inches.  I had enough travel that I almost put the front wheel on the foot board.  I do not want to cut the grille so I will need to get creative there.  Good thing it is the first of June and not Nov.  I'd be in a heap of hurt. I'll be hurting enough due to the heat. We are already hitting 100.... Sad
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 1st 2018, 4:58 pm
Ooh that sucks.  Glad it's mostly done though!
Meantime in Texas we are hitting 104....
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 1st 2018, 5:23 pm
Looking good! Yeah the reason I moved the axle forward when I did the Murray front end was because of the limited front end space. On the muckraker I am putting a stuck up front end look on it so I can leave the axle in a closer to stock postion.
Our humidity was 80 percent with 98 degrees. Sit outside and your pouring sweat, loaded up the trailer right all my scrap machines and my clothes were drenched.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 1st 2018, 5:51 pm
That sucks. Gonna have room to move all the suspension and mounts forward, or are you gonna have to extend the frame?
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 1st 2018, 9:49 pm
Hmmmm.... You would loose some travel, but would it be possible to just rig up some bump stops for the suspension so the front wheels won't go up near the foot boards?
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 1st 2018, 10:25 pm
The front tires are just too large for the position they are in.  I thought a couple inches forward would be enough.  I guess not.
I am unsure of what I am going to do at this time. I'm going to sleep on it and think about it tomorrow.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 2nd 2018, 12:12 am
Yeah that's what I though from the get go. It will look a lot better with the big tires when the axle is moved forward.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 2nd 2018, 9:43 am
Doing some looking and I have a pretty ugly top attachment point for the little shocks. I think I will make a new one and place it in front of the grill on the bumper braces. I am pretty certain they are strong enough. I have bounced my weight on the front corner of the bumper with no bending. Then I will make a new monolink for the front axle and keep the same attachment point under the tractor.
I am glad I held off on the exhaust. This will open me up in front of the engine for some more options on running pipe.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 2nd 2018, 9:51 am
Hopefully it works out for the better. I always thought the wheelbase on this was a little short, I was just withholding judgment till I saw it with the body on but the nose sticks out past the front wheels
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 2nd 2018, 9:54 am
Simple solution. Smaller tires.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 2nd 2018, 10:33 am
My only cencern moving forward is I will be getting into the bumper.. So some extending maybe. LOL smaller tires.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 2nd 2018, 10:40 am
Well hey, it is the fastest and the most sure way to have clearance without redoing frame work.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 4th 2018, 5:00 pm
All was good.  I did move the axle forward a bit in original design, but did not account for the size of the tire and articulation of the front end.  When doing my flex test I may have gotten the tire what was it about 7 inches off the ground, but what I didn't account since I was on flat ground, was the other side's ability to DROP.  I should have taken a picture, I had the left side down as far as the right side was up.  This gave more angle to the "up" tire allowing it to easilly grab the foot board.
I can't tell you how many times I have contemplated doing that this weekend.  With those massive rear tires, I don't think it would look right with smaller tires.   I spent the better part of the weekend cleaning and re-arranging the garage so I have more working space.  I hope to put the front on stands and remove the front axle and ponder it.  Maybe rework and make it better.  As I mentioned, if I move it forward a bit, will I run into my bumper?   Will I need to stretch that out a little?  We will see.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 4th 2018, 7:14 pm
Doing some measuring and came up with a
Plan A:
Move the axle 3" forward and a 2" lift should clear everything.
If not.
Plan B:
Redo the whole monolink and stretch out the bumper.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 4th 2018, 7:17 pm
Hopefully Plan A works out for ya Mighty, that seems like the simpler route, haha.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 4th 2018, 8:42 pm
Yeah, bit it will have a even more stuck up look.
PostSubject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]    [Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 Icon_minitimeJune 4th 2018, 10:57 pm
HAHA... nose in the air. We'll see how it all pans out.
[Complete] Mightyraze's Kal-El [2018 Build-Off Entry]  - Page 21 06041810
Page 21 of 30Go to page : Previous  1 ... 12 ... 20, 21, 22 ... 25 ... 30  Next
» [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
» [Complete] Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
» [Complete] Redzz02's Haspin Build [2018 Build-Off Entry]
» [Complete] Mr.Modified's Craftsman HE [2018 Build-Off Entry]
» [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive :: Finalist Archive-
