| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
Thunderdivine Veteran Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 9th 2018, 9:46 am | |
| Trying a high res image due to reports of image issues. it appears to be working today. As you can see not much progress on Kal.
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
Crazy_Carl Veteran Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 11th 2018, 6:26 pm | |
| Well that do-hickey has now become a part of the bumper.... This will move the axle forward about 6.5-6.75 inches and lowers the front end about a 0.75-1 inch. Front end is still on stands and shocks extended about half an inch. Just need to extend my pivot for the monolink. | |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 11th 2018, 8:33 pm | |
| Looks good Mighty! Should solve the problem. Also I can see the difference in wheelbase length and I think it looks better now! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 11th 2018, 9:09 pm | |
| Thanks guys! It has been a slow go today as my knee feels like the lower part of my leg may fall off at any time. One thing about the heat outside is it helps my knee feel better. Here is most everything back together. Now I need to extend the monolink about 6.5-6.75 inches and reattach. I think I will just cut the ball back off and run some square tube for the extension then weld it back together. Hopefully straight. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 11th 2018, 9:59 pm | |
| Wow I'm really impressed with how you made new shock towers that could move the axle forward and look pretty cool at the same time. Doesn't look hack at all. It's looks like you planned it this way all along.
I like the idea of extending the mono link more than moving the mount. Easily to weld that than crawling under the tractor, cutting the mount off, moving it forward and bracing it up.
Just take your time tacking up the mono link and checking it with straight edges. It'll be fine. | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 11th 2018, 11:48 pm | |
| That and the new setup seems to make the bumper a little more sturdy. Definitely makes it easier to get it on and off as well as the hood. I just hope to not cause a weak point in the monolink. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 12th 2018, 11:46 pm | |
| Yeah, not too worried about a weak point now. Chopped the joint off Welded an extension. I did put a slight upward bend to it on purpose. Reattached the ball. Kal back on all 4s. I need to make a new steering rod. I was making a new one and ripped the top of my vise off the base cracking the base in 2 pieces. I have welded it back together but had to leave before I could test it out. I do have some give should I need to bring the axle back a half inch or so. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 12th 2018, 11:52 pm | |
| Looks awesome with the new wheel base Mighty!! I gotta say though, in that third picture I seriously though you had a rack and pinion installed on the front of the axle for a split second, then i realized it was just the coilovers. Looking good! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5093 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] June 13th 2018, 12:23 am | |
| Thanks! I have been studying what I have yet to do and what I need to do. It looks like I may need to add a brace for the food boards? They look droopy in those pictures. That will be a last thing. | |
TheCollector Member
Age : 38 Join date : 2015-04-22 Points : 3733 Posts : 194 Location : Bedias. Tx
