| [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] | |
+18TheCollector MatthewD CraftsmanQuad19 SebastianAlbrecht Buck TheBeal RichieRichOverdrive Dave 007 mrshaft696 Crazy_Carl Dave.MTD Doug prancstaman AllisKidD21 biggasmowers Double W Cross Ranch muckmudd MightyRaze 22 posters |
biggasmowers Veteran Member
Age : 24 Join date : 2016-12-30 Points : 4927 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 18th 2018, 7:02 pm | |
| Did a little work on the tractor today as we were suppose to have storms that never happened. Measured my cutouts needed for the grille and cut them out and temp mounted to the frame. Feeling good enough to go ahead and button down the engine. I still need to sand and paint the other head tins. Also need to find out what size screw the little ones at the bottom are. EDIT: Yes the tread is backwards on the front left. I put the rim on backwards. LOL. | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3558 Posts : 825 Location : In the shop
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 18th 2018, 7:05 pm | |
| Lookin good for sure. You didn't have to chop off nearly as much as I did have to on the lt130 thankfully eh? IDK if its just the way the picture is taken but the wheel base seems pretty close together. Usually I like mine a little wider but I guess it's just personal preference. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 18th 2018, 8:10 pm | |
| I've actually pushed the front axle out 2 inches. Its those large fronts. Ask @Crazy_Carl about them. They are pretty big! Carl's Ride... Mine... I am also planning using some 2 inch spacers on the rear. It will help those monster rear tires fit better. | |
Crazy_Carl Veteran Member
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 18th 2018, 9:35 pm | |
| LOL maybe not 2" up, but more on the lines of 2" out. I was actually going for a nose up design. With the nose together I can start building my front bumper, getting ideas and see where it takes me. | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 20th 2018, 11:52 am | |
| If that's a pressure lube oppy I wouldn't worry too much about the chassis being raked back like that. Splash lube motors are more picky about how level the crankcase is to ensure oil gets splashed everywhere it needs to go. | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 20th 2018, 11:56 am | |
- Yeah thats a ton of angle, definitely level her out.
Nah that's nothing to worry about. Red's MTD had way more nose up and he ran a splash lube opposed with the upper cylinder facing rearwards, it never hurt anything. Worst case scenario add a little more oil than called for to make sure it's always being splashed around. I think the nose up makes some rigs look meaner! Haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 20th 2018, 12:44 pm | |
| I was also going to point out Red's. LOL Also another thing to point out. It isn't that much nose up as the pictures show. Some reason my phone is starting to fisheye stuff. Also, I hope I do more than run it up and down the road! Hopefully I have it sideways, pointed way up, then down... just hope not upside down. Edit: I also need to check tire pressure in those tires. I may still have bead setting pressure on them. LOL | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 20th 2018, 2:18 pm | |
| - Crazy_Carl wrote:
- If that's a pressure lube oppy I wouldn't worry too much about the chassis being raked back like that. Splash lube motors are more picky about how level the crankcase is to ensure oil gets splashed everywhere it needs to go.
Has anyone ever seen inside a splash lubes oppy? This talk makes it sound like it's just a little spur on the end of the crank. But it's actually a very good setup internally There's a mechanism that hold two rotating gears with large paddles on them and it connects to the timing gear drive gear on the crankshaft. It sprays oil everywhere and even if there's not much oil it pulls it up from the bottom . | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5714 Posts : 1402 Location : Central PA
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 20th 2018, 6:15 pm | |
| It isn't a bad system, but at real low RPMs the upper cylinder and upper crank bearing sometimes don't quite get as much oil as they should. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 20th 2018, 11:19 pm | |
| OH MY GOSH.... I wish I could show you the sheer scale of this thing now. I was curious and put the body down on the frame. Wow.... Then - Code:
[img]http://mightyraze.com/wp-content/gallery/pops/82_Murray-1.jpg[/img] Now OK, i'm starting to get really excited again.
Last edited by MightyRaze on October 22nd 2018, 3:39 pm; edited 1 time in total | |
Dave.MTD Member
Age : 24 Join date : 2017-01-11 Points : 2907 Posts : 37 Location : Hamilton, Ontario
| Subject: Re: [Complete] Mightyraze's Kal-El [2018 Build-Off Entry] March 20th 2018, 11:42 pm | |
| - Dave.MTD wrote:
- Wow - it grew! lol
What kind of ground clearance do you have right now? I was curious too so I already have those measures. Front Axle - 12 inches Front Tierod - 10 inches Bottom of frame - 16 inches Transaxle - 9.5 inches Rear Plate - 9 inches | |
