| | My Rat Rod Mower | |
+13RichieRichOverdrive Mikethepigman MightyRaze Doug Deek AllisKidD21 MatthewD prancstaman mr.modified CraftsmanQuad19 redlinemotorsportts Ryf jahneygeee 17 posters | |
| Subject: Re: My Rat Rod Mower March 10th 2017, 7:58 pm | |
| Thanks! I like them too haha, I just got to find a way to secure them while making sure they don't try and move when the spindle turns. Hopefully I'll figure something out. | |
| Subject: Re: My Rat Rod Mower March 11th 2017, 11:07 am | |
| I can see where that could be hard. I've thought about it for about 5 minutes and haven't thought of a solution for that to help. I'll keep my wheel in my head going. | |
| | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5683 Posts : 1402 Location : Central PA
| Subject: Re: My Rat Rod Mower March 11th 2017, 11:46 am | |
| I dont know what they are called, but they look like thin washers, and have a slight bend in them. If you cold fins the big enough to fit inside the spikes, then tack them in place, that might work.
Then there is something else, again I dont know what they are called, but they look like a top hat. Ill try to find some pictures.
Im not sure you have enough material sticking up past the cotter pin for these to work, but may be worth a try.
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8553 Posts : 5190 Location : Ontario Canada
| Subject: Re: My Rat Rod Mower March 11th 2017, 12:02 pm | |
| Thanks guys! Your suggestions are much appreciated cuz I got nothing really hahaha! I do like the way they look on the spindles like that so hopefully we'll think of something. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 11th 2017, 4:07 pm | |
| I was thinking of some way to snap the cone down on the washer. Or.. Some way to pin it to the axle. | |
| Subject: Re: My Rat Rod Mower March 11th 2017, 5:58 pm | |
| Yeah, if I put washers underneath the cotter pins I supposed the plastic covers would slip over the washers and stay there. Hmm... maybe I'll try that after March Break. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 11th 2017, 10:54 pm | |
| Thanks! I just saw a washer laying on the same table my engine was on, and I thought...why not? Hahaha! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 10:35 am | |
| I'm back to working on the rat rod daily now. Although nothing major done lately, I'm still getting some small stuff done. I'm liking the way it looks with the new front axle though hahaha! I'm also sort of starting get to tear the engine apart in preparation for some minor modifications. That's all for now! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 24 Join date : 2016-04-12 Points : 5938 Posts : 2636 Location : Indiana
| Subject: Re: My Rat Rod Mower March 21st 2017, 11:03 am | |
| But she started so easy....why change anything? | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 11:19 am | |
| That is definitely true hahaha. But the stuff I'm going to do is only going to help that. It's nothing major. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 11:53 am | |
| Looking good! You always had that jumper clamp on there? HAHA | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 12:35 pm | |
| - CraftsmanQuad19 wrote:
- But she started so easy....why change anything?
HAHAHAHAHAHAHA....I feel dumb now I thought this was your MTD thread LOOL! | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 1:14 pm | |
I thought this was your MTD thread LOOL! Oh hahaha! Nice, I was wondering why you asked, hahaha! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 1:16 pm | |
| - mightyraze wrote:
- Looking good! You always had that jumper clamp on there? HAHA
Thanks mighty! Yeah that has pretty much been there since the beginning. I might have taken it off at one point though, I'm not sure haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5719 Posts : 1993 Location : Northern Ireland
| Subject: Re: My Rat Rod Mower March 21st 2017, 3:11 pm | |
| Probably just some porting, maybe remove head and shave eyebrow. And my timing advance trick. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 7:05 pm | |
| Has the governor already been removed? And if you can get your hands on one, get a OHV cam to put in it. I have one waiting to go in the 11 horse on the CQ whenever I have it apart
| Subject: Re: My Rat Rod Mower March 21st 2017, 8:02 pm | |
| No it hasn't, I'm probably going to retain the governor assembly just cause I like having it. I did see your High Hour 11 engine build and I thought about maybe putting an OHV camshaft in mine. But we'll see haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 34 Join date : 2013-11-02 Points : 7130 Posts : 2907 Location : New Jersey USA
| Subject: Re: My Rat Rod Mower March 21st 2017, 9:14 pm | |
| Not a huge rat rod fan, but this is looking pretty nice. | |
| Subject: Re: My Rat Rod Mower March 21st 2017, 9:15 pm | |
| Thanks a bunch Mr.Mod! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 22nd 2017, 8:59 am | |
| Haha works just as good as sheet metal! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 22nd 2017, 9:25 am | |
| I think it adds nicely to the character of the tractor! | |
| Subject: Re: My Rat Rod Mower March 22nd 2017, 9:57 am | |
| Thanks! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: My Rat Rod Mower March 22nd 2017, 10:54 am | |
| Mostly working on the engine today again. I took the coil off so I could clean the rust off of the coil pickup and the flywheel magnet. And also I decided to try and get the block down to bare aluminum because I think it would look cool with the blue blower shroud. Before: After: Hopefully I can get the whole block to look like that, I think it looks pretty cool, hahaha! Let me know what ya think! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests
