 Backfiring out the carb
Dipshaw87
7 posters
Backfiring out the carb - Page 2 Empty
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 12:21 pm
this is how i set mine up, mine is a 10 horse, smaller carb, but same family of carbs. so, it should work for you.
i removed the fuel pump that was threaded in, and put in a 1/4 inch brass nipple.
Backfiring out the carb - Page 2 NCM_02681_zps87f5f2db
i got a new style Mikuni pump from "jim micco and sons on ebay" for about 15 bucks
Backfiring out the carb - Page 2 NCM_02691_zps3fcec6a7
ran a line from the crankcase breather, about 6 inches long, then another from the filter to the intake on the pump, and then another, about 12 inches long to the carb.
Backfiring out the carb - Page 2 NCM_02701_zps8dffdaad
this setup has never let me down, even hanging freely like it is. when i paint it for the buildoff, i plan on fastening it to the shroud, and making everything pretty
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 1:07 pm
What model fuel pump is that? And the flywheel key is in good shape and not sheared
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 1:23 pm
willis923 wrote:
good catch doc, i completely missed the flywheel key. thats why we have forums though, teamwork
Precisely.
Those pumps appear on all sorts of OEM applications, including the Vanny twins.
Quote :
Well, pity that the problem's not yet solved. however- eliminating it as a possibility is actually forward progress, even if it doesn't feel like it.
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 1:31 pm
Oh ok so any oem fuel pump would work? And yea it honestly feels like I'm getting nowhere on this thing lol
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 1:41 pm
Pretty much any diaphragm style pump, that will deliver less than 5psi, or you'll run into flooding issues.
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 1:45 pm
Ok. Now I have a question am I able to use a completely different carb like a kohler #26 or something else on this engine? Or should I just look into getting a whole new walbro carb if the fuel pump idea doesn't work
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 1:52 pm
Fitting a non-stock carb leaves 4 hurdles to jump.
1)Mounting. If it doesn't bolt right up in the correct orientation, you gotta get creative.
2)Venturi size. Too big is just as useless as too small.
3)Jetting. Odds are pretty good that you'll have to play with the mixtures. Easier on some carbs than others.
4)Governor linkage- if the carb didn't come off your engine type, 99% chance you're gonna have a real problem with the governor.
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 1:55 pm
Never thought of that lol ok let me try the fuel pump idea. I'll see if I can get one off amazon or somewhere cause I don't have any laying around here
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 2:01 pm
Is there any fuel pump I should stay away from?
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 2:21 pm
None that I can think of. I like these, because they are rebuildable. ---> http://www.arcracing.com/servlet/the-23/pulse-fuel-pump-Mikuni/Detail
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 3:44 pm
Have you used that pump before?
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 5:56 pm
i meyself havent, however, mikuni is one of the most respected names in fuel delivery systems
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 6:17 pm
Ok so let me ask this. I'm not that good with old style carbs at all. If it's running to lean then it backfires out the carb and if it runs rich will it backfire out the exhaust? Can it be backfiring because of the valves needing adjusted?
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 6:39 pm
Yup. Also use the one Willis showed.
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 6:40 pm
If intake valve is not closing completely, or out of adjustment, it can cause backfiring in carb.
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 6:42 pm
What model number was that one that Willis showed? And I thought about that but I'm not sure of the specs for the valve lash
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 6:46 pm
Would a bad float have anything to do with this?
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 7:43 pm
a float could be sticking or hanging up, not allowing it to drop all the way and restricting the fuel flow into the bowl. before you go buying parts, i'd take the bowl off, inspect everything one last time. THEN spend cash on parts. in regards to the fuel pump, i dont have a model number. theyre all the same anyway.
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 8:18 pm
Ok I've taken the carb off 4 times and still I don't know what all to do. But I'll work on it more tomorrow and keep you guys updated. I thank you guys very much for helping me cause I don't know what I'm doing lol
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 8:34 pm
All do-able, if ya have years of experience with engines like some here do... not something I'd recommend to the beginner.
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 23rd 2014, 8:49 pm
Here's a video of the bolens
https://youtu.be/7-unQLWByeQ
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 24th 2014, 3:12 am
I'd check the valve lash.... I'm thinking it is an overhead valve engine. I think the valves are gapped too small and your intake is staying open once the engine warms up
Forget the carb and governer for now, and check the basics... valve lash first, then timing
Just my two cents
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 24th 2014, 8:16 am
What are the valve lash specs for that engine?
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 24th 2014, 8:59 am
Google can tell ya quick. 4 to 10 thousanths on the OH16. 5-6 thousanths is a good starting point for most OHV small engines.
(ref. http://outdoorpowerinfo.com/engine_specs/tecumseh_valve_gaps.asp ) ( ... The last entry on the page)
this vid shows correct governer and carb linkage
https://www.youtube.com/watch?v=l1_QOJt_0_g
Dipshaw87
Dipshaw87
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 24th 2014, 9:00 am
Thanks! Will these specs work for the 16 hp?
PostSubject: Re: Backfiring out the carb   Backfiring out the carb - Page 2 Icon_minitimeFebruary 24th 2014, 9:03 am
it shows 13.5 - 17 hp, so yeah
» Tecumseh hh100 carb
» Need a new carb!
» Backfires when brought to low idle
» help need cub 106 carb
» CARB KIT HELP !!!
