| Backfiring out the carb | |
+3redlinemotorsportts willis923 Dipshaw87 7 posters | |
| | | | Dipshaw87 Member
Age : 29 Join date : 2014-01-02 Points : 4154 Posts : 135 Location : Vanderbilt, Pa
| | | | Dipshaw87 Member
| Subject: Re: Backfiring out the carb February 25th 2014, 10:27 pm | |
| Well I'm trying to get a set of valve spacers so I can measure the gap between the rocker arm and valve. I have some I just can't find them lol | |
| | | Dipshaw87 Member
| | | | Dipshaw87 Member
| Subject: Re: Backfiring out the carb February 26th 2014, 1:17 am | |
| Ok so I've been doing research online about the lmh 32 walbro carbs. Apparently there are 2 oem replacement for those that fits the tecumseh oh160. It's the walbro whg 17-1 and 16-1. The first one (17-1) has an adjustable high speed jet and the 16-1 doesn't. But everything else like the Venturi size are the same on those as the lmh 32. | |
| Subject: Re: Backfiring out the carb February 26th 2014, 8:49 am | |
| - Dipshaw87 wrote:
- Well I'm trying to get a set of valve spacers so I can measure the gap between the rocker arm and valve. I have some I just can't find them lol
you can just get a set of feeler gauges from a local auto parts store, probably for less than 10 bucks | |
| | | Dipshaw87 Member
| | | | Dipshaw87 Member
| Subject: Re: Backfiring out the carb March 1st 2014, 7:31 pm | |
| I'll get to adjusting the valves tomorrow afternoon and I'll try and post pictures up | |
| | | fast adam Member
| Subject: Re: Backfiring out the carb December 22nd 2014, 9:49 pm | |
| Is there an air filter on it? Is it bolted to the block good and tight? | |
