| Backfires when brought to low idle | |
kieranruffell Member
Age : 24 Join date : 2014-01-22 Points : 4014 Posts : 43 Location : Whangarei, New Zealand
| Subject: Backfires when brought to low idle January 26th 2014, 4:21 pm | |
| My kohler 12.5hp backfires when throttled down to low idle. Any suggestions on how to fix this. Thanks | |
Age : 28 Join date : 2013-04-10 Points : 5761 Posts : 1408 Location : Galway NY
| | | | TroyBilt Pony Established Member
Join date : 2013-06-01 Points : 4810 Posts : 578 Location : West Virginia
| | | | Lawren Wimberly Established Member
Age : 57 Join date : 2013-12-21 Points : 4805 Posts : 744 Location : Salem Illinois
| Subject: Re: Backfires when brought to low idle January 26th 2014, 4:50 pm | |
| probably not enough lash in the intake valve. The plug actually fires on the exhaust stroke too... if there is sufficient fuel still in the exhaust, it will fire out of turn
| | | | Doc Sprocket Site VIP
| Subject: Re: Backfires when brought to low idle January 26th 2014, 7:28 pm | |
| First place I'd look is the mixture, may well be on the lean side. I've had engines do this after instaling a free-flow exhaust system, before I'd had the chance to adjust the mixture to suit. | |
| | | T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4572 Posts : 540 Location : Central MA
| Subject: Re: Backfires when brought to low idle January 27th 2014, 2:45 pm | |
| Lean. Most likely the carb like most are saying. The other major cause of backfiring is an exhaust leak. Air getting inside the exhaust system then you let off of the throttle. Is your exhaust tight and not leaking? | |
| Subject: Exhaust January 27th 2014, 3:03 pm | |
| I have recently replaced both bolts and the exhaust gasket. I am pretty sure there are no holes in the exhaust and the bolts are tight. Thanks for the tips.
Last edited by kieranruffell on January 27th 2014, 3:07 pm; edited 1 time in total | |
| Subject: Carb January 27th 2014, 3:05 pm | |
| Last night i cleaned the carb just need to find time to put it back on and readjust it. Hopefully it makes a difference. | |
| Who is online? | In total there are 75 users online :: 0 Registered, 0 Hidden and 75 Guests
