| The Red Fox | |
+17mrkadage mr.modified GenevaCustoms Craftsman1998 T-Dub13 LAWN MOWER MUDDER redlinemotorsportts Creepycrawler 1997 Murray TheBeal TroyBilt Pony camomanusa redzz02 willis923 Thunderdivine Doc Sprocket Lawren Wimberly 21 posters | |
| Subject: Re: The Red Fox March 13th 2014, 6:48 pm | |
| Yook off the electric motor and SURPRISE! MY variant does NOT have a shaft, it has a helical gear on the MOTOR shaft. GRRR! so I'm going to have to cast an aluminum carrier for a homemade right angle gearbox using the gears from the MTD FNR to drive the helical input gear On the plus side, I have springs, shackles, axle, shocks, anti sway bar, and dual mechanical drum brakes... it may be worth the effort. | |
| Subject: Re: The Red Fox March 13th 2014, 9:25 pm | |
| That or... Keep your onan generator engine combo together and put the electric motor back with the golf cart axle. Then with some converting from 110v to 24/48v (whatever golf carts are), you won't need a clutch or transmission. Not that that's the thing to do with something like this, but just a cool idea to think about. Neat thing with that would be you don't need to line anything up and you can put the engine where ever you want. Also while i'm thinking about it, don't those old onan generators use the gernerator as a starter? Hence if you remove the generator you won't have a starter. Not that you couldn't rig something up fairly easy, but I was just wondering. | |
Age : 57 Join date : 2013-12-21 Points : 4802 Posts : 744 Location : Salem Illinois
| Subject: Re: The Red Fox March 13th 2014, 9:49 pm | |
| The cck engine has an automotive type ring gear starter. While yes, I could do it that way converting the 220AC to 36v DC (an old fork lift charger or welder transformer would work) I prefer to go the mechanical route. A lot of the treehugger cars out there do basically the same thing. | |
Age : 49 Join date : 2012-04-05 Points : 5698 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: The Red Fox March 14th 2014, 10:25 am | |
| I see a sliding gear/shifter, looks like the golf cart axle has a high/low? O wait, I think that's a reverse...
You could also use an old car rear axle for a RAGB. Depending on what way you mount it, gives you some ratio options. | |
| Subject: Re: The Red Fox March 14th 2014, 10:28 am | |
| O! WAIT! You could put the transmission, and axle, in reverse at the same time, and have a really low forward gear! | |
| Subject: Re: The Red Fox March 14th 2014, 10:36 am | |
| Unfortunately, when I tore into my axle, I found a different variant to the one I showed. I pulled that pic up from an ezgo website. While it LOOKs the same on the exterior, mine is completely different on the INSIDE. GRRR!
I think the one shown is a gas engine axle, and the shift fork is reverse/forward. "lectric just switched poles for reverse. It's gonna take some engineering feats to make it work, I'll try to keep ya posted.
| Subject: Re: The Red Fox March 14th 2014, 10:43 am | |
| DARN. I was going to randomly shift your axle in reverse at haspin....
I'd try to find a gas one then. The more levers/shifters, the better! | |
| Subject: Re: The Red Fox March 14th 2014, 10:44 am | |
| If you want a MASSIVE transfer case, I have one out of a deuce and half, 100 bucks! | |
| Subject: Re: The Red Fox March 14th 2014, 10:48 am | |
| I think ezgo actually stole the case design from peerless... it's very similar to the 1200, just the internals are quite different. I'm heading to the sawmill today, and the ole farmer that runs it has an old Golf cart or 2 laying around... maybe I'll get lucky and find a front drive dana axle (they made some for thes things... it's kinda like a mini car axle)
and stretch..... Remember evil deeds come back in spades (evil eye) be nice or silver bullet could end up as a hood ornament! | |
| Subject: Re: The Red Fox March 15th 2014, 6:36 pm | |
| THIS is the diagram for my axle... I have found a piece, and the associated bearing assembly on line to convert the innie into an outtie... 'cept it's 89 dollars for the bearing and shaft assembly.... NOPE That just goes against my entire junkyard mentality. SOOOOO.... Plans are to take the shaft from the rotor (inside the electric motor) shorten it so that I can use the front and rear bearings to support the shaft, and use the original drive assy MINUS the electric motor... I'll take pics along the way to keep ya posted on difficulties as they spring up. | |
| Subject: Re: The Red Fox March 15th 2014, 10:53 pm | |
| - Lawren Wimberly wrote:
- The cck engine has an automotive type ring gear starter. While yes, I could do it that way converting the 220AC to 36v DC (an old fork lift charger or welder transformer would work) I prefer to go the mechanical route. A lot of the treehugger cars out there do basically the same thing.
I don't think the "cool factor" is really there with electric power. At least not for this project. | |
| Subject: Re: The Red Fox March 16th 2014, 3:44 am | |
| I WILL admit that that has a bit to do with my decision... It's too easy. | |
| | | Doc Sprocket Site VIP
| Subject: Re: The Red Fox March 16th 2014, 8:54 am | |
- maybe I'll get lucky and find a front drive dana axle (they made some for thes things... it's kinda like a mini car axle)
I've seen these, they're brilliant for an application like this. I been keeping lookout for one too. I know SOME of them (maybe all, not a golf cart guy) came equipped with a CVT, with the driven mounted directly on the differential pinion flange. | |
| | | | | The Red Fox | |
| Who is online? | In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests
