 Push / Pull system for Gear shift.
2 posters
Push / Pull system for Gear shift. Empty
PostSubject: Push / Pull system for Gear shift.   Push / Pull system for Gear shift. Icon_minitimeDecember 10th 2013, 9:55 am
I'm seing this as a good idea if you have a lifted mower with springs or shocks.
Then a Push / Pull wire system would do the trick for you.
Thus eliminating the need for the solid shift rod.
PostSubject: Re: Push / Pull system for Gear shift.   Push / Pull system for Gear shift. Icon_minitimeDecember 10th 2013, 10:00 am
Yep. I often use cable actuation where others use linkages, such as clutches and brakes. You can either use a heavy Morse cable for push-pull, or two standard cables for pull-pull. I get automotive parking brake cables from my favourite surplus store.
» Shift on the go trans wont shift :(
» My restored push mower.
» B&S V-Twin 24 Hp Push rod problem
» tractors with push mower engines
» push mower engine conversion/ rev limiter
