| Shift on the go trans wont shift :( | |
Minimechanic New Member
![Minimechanic](https://2img.net/u/2812/37/66/46/avatars/853-59.jpg)
Age : 27 Join date : 2013-04-17 Points : 4185 Posts : 16 Location : Maine
![Shift on the go trans wont shift :( Empty](https://2img.net/i/empty.gif) | Subject: Shift on the go trans wont shift :( April 18th 2013, 8:04 pm | |
| I took apart my shif on the go trans axle and i took everything out of it and put it back together but now it doesn't seem to shift when i go to shift, all the linkages are hooked up | |
![Shift on the go trans wont shift :( Empty](https://2img.net/i/empty.gif) | |
![Shift on the go trans wont shift :( Empty](https://2img.net/i/empty.gif) | Subject: Re: Shift on the go trans wont shift :( April 18th 2013, 8:51 pm | |
| Well i don't have a belt on it lol it shredded the last one but the neutral forward reverse feels like its not shifting right and how did you switch it over because i might do the same lol | |
Marines2621 Member
![Marines2621](https://2img.net/u/2812/37/66/46/avatars/537-64.jpg)
Age : 27 Join date : 2012-12-31 Points : 4509 Posts : 215 Location : Mountainburg, Arkansas
![Shift on the go trans wont shift :( Empty](https://2img.net/i/empty.gif) | Subject: Re: Shift on the go trans wont shift :( April 18th 2013, 11:13 pm | |
| Did u put the ball back in, put the gear up front together right. Recheck yourself. I took my apart. And had no problems running it | |
Marines2621 Member
![Shift on the go trans wont shift :( Empty](https://2img.net/i/empty.gif) | Subject: Re: Shift on the go trans wont shift :( April 19th 2013, 7:54 am | |
| I didnput the ball back in it and i did assemble the gear up front correctly because i didnt dissasemble it haha, and ill try turning the imput shaft today and see what happens | |
![Shift on the go trans wont shift :( Empty](https://2img.net/i/empty.gif) | Subject: Re: Shift on the go trans wont shift :( April 19th 2013, 8:41 pm | |
| I checked it today and everything is all good it just shifted a lot smoother since i rebuilt it so its all good thanks guys! | |
b1gmarv New Member
![b1gmarv](https://2img.net/u/2812/37/66/46/avatars/1011-40.jpg)
Age : 35 Join date : 2013-07-10 Points : 4090 Posts : 9 Location : ocala,fl
![crazykid1994](https://2img.net/u/2812/37/66/46/avatars/750-21.jpg)
Age : 29 Join date : 2013-03-18 Points : 4851 Posts : 618 Location : loxahatchee, florida
b1gmarv New Member
b1gmarv New Member
