| Murray shift on the go trans | |
dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4805 Posts : 141 Location : central Wisconsin
| Subject: Murray shift on the go trans July 16th 2012, 12:49 pm | |
| I picked up a Murray with the shift on the go trans. Has anyone used this system, or is it better to eliminate it and go with standard type shifter and clutch for offroading and trail use? | |
| Subject: Re: Murray shift on the go trans July 16th 2012, 6:22 pm | |
| Ive used one for a mod ( fast) - best thing about it is theres no clutching - when you pull the shifter, that does the clutching shifting up . Its actually a 'standard' 5 or 6 speed trans under it.
It uses gear oil ( i filled mine with lucas oil and 90 wt gear oil) - it held up for a couple years at 30mph and never failed ( still out by my shed). | |
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5803 Posts : 511 Location : Southern WV
| Subject: Re: Murray shift on the go trans July 16th 2012, 8:29 pm | |
| Do either of you have any pics of this shifting setup? I've never heard of it I don't think. I'd be interested to see how it all works. | |
dked41 Member
| Subject: Re: Murray shift on the go trans July 17th 2012, 9:46 am | |
| Sorry, tried to get some pics but the camera I have doesn't focus very well close up. What it does is clutch the belt when you pull the shifter out of the notch for each gear. The gear notches are deeper and as you pull the shifter out of the notch, it has linkage that moves the idler pulley to disengage the belt while you change gears. There is a foot brake/ clutch setup like a normal tractor also. | |
dked41 Member
dked41 Member
dked41 Member
dked41 Member
dked41 Member
| Subject: Re: Murray shift on the go trans July 20th 2012, 7:09 pm | |
| Its a neat setup - whoever came up with it at murray - ive been contimplating removing the setup from my mod murray to a older craftsman chassis , so i can get it lower.
As simple as the setup is, it works really well . You do need to clutch when downshifting tho . | |
N.jeffries10 New Member
| Subject: Re: Murray shift on the go trans January 4th 2013, 4:01 pm | |
| Does anyone know if a shift on the go type trans would work for a pulley swap? I'm trying to make my first racing mower and one of the mowers im looking at is yard machines 17hp but it has a shift on the go and I'm not sure how well that would work. Heres a link to the mower http://chicago.craigslist.org/nwc/for/3516797759.html I'm also open to any suggestions you may have. Thanks for any input! | |
| Subject: Re: Murray shift on the go trans January 5th 2013, 4:45 am | |
| Its called a 'shift on the go' but its not the same as a murray - it has a variable pulley in front of the seat and the trans is basically a forward/neutral/ reverse.
$200 is alot to spend on something thats going to be modifed - if you keep looking something cheeper will come along.
MTD's can be 'tweeked' - the high speed linkage needs to be adjusted , just as long as the neutral setting stays the same( or itll crawl with the clutch in).
MTD's have a splined transaxle shaft - so unless the stock pulley center is cut out and rewelded in another pulley - itll be a bit hard to find one thatll fit.
Easier way is to swap a geared trans in or a peerless 700 with a straight rear axle. | |
davidgt6000 Member
| Subject: Re: Murray shift on the go trans March 7th 2013, 5:11 pm | |
| i just got one of the mtd statesman today that has the shift on the go. 6 speed with forward/neutral/reverse. however i am having a problem to get it freewheel its in neutral but its like its in gear, any ideas?/ | |
