 tractors with push mower engines
Bio Hazardra
7 posters
Bio Hazardra
Bio Hazardra
tractors with push mower engines Empty
PostSubject: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 12th 2016, 11:55 pm
I was just wondering who here has tried putting push mower engines, 8 hp and smaller, mainly in the 6.25 and under range, on a tractor?
ive seen multiple pictures of these and a video or two but wonder just how much power one would have. not for mudding but just offroading. maybe step hills and suck. to me a small push mower Briggs engine is more reliable than any lawn tractor engine (in my experience) and i want something reliable on the tractor im building more than something powerful
if you have done such a engine swap, please post pics and links to threads if its on here down below. Im very curious! Very Happy
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 13th 2016, 11:34 am
It's all in the gearing. You could get pretty much any engine to work on a tractor if you work the gearing right. If you kept the stock pulley sizes a push mower engine would be fine. You would have to drill a slightly smaller bolt pattern for to bolt the engine down though.
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 13th 2016, 2:06 pm
Chevy8988 used a push mower engine in his Frankenstein racer, and it worked fine.
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 13th 2016, 2:20 pm
You can make a 1/2 horse engine pull a train, geared right....at about an inch per day.
Now this obviously won't be as extreme, but you won't really be getting anywhere fast. At least not without starting in low gear and shifting up as you go.
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 13th 2016, 2:42 pm
Agreed. My old walk behind tractor has only 6.6hp, and it's a ground engaging machine. It's not all about power, you gotta get it to the ground too.
Bio Hazardra
Bio Hazardra
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 13th 2016, 3:57 pm
i figured they would do pretty good on one. thing is i already pulley swapped my tractor project so it would be harder on the small engine to pull it. I think i might put one on the racing mower i plan on making this winter if i can find a decent one somewhere
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 13th 2016, 5:32 pm
It depends how my HP you're push mower engine is. If it's a little 3.5hp Briggs then it won't do much more than stock speed, but if it's 5/6 then I'd say you'd be able to do at least 15-20. If you think about it, my 5.5hp go kart can do 35mph and it's got a pretty heavy tube frame.
Bio Hazardra
Bio Hazardra
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 14th 2016, 1:44 pm
thing is im a big guy and i want to take it on some steep places on my farm. a really small engine pulley with a stock tranny pulley would work fine i would say. doesnt need to be fast anyway. low end torgue (what little there might be) and slow, crawling capability is what would be best
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 14th 2016, 2:10 pm
If you start off in 1st gear and change up 1 by 1 to 5th/6th whatever your top gear is, you could get away with less HP and if you wanted to climb hills, you just change down into 1st/2nd. What kind of HP Push mower engine are you wanting to use?
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 14th 2016, 7:30 pm
I've put a 6.5 pressure sprayer motor on a Troy Bilt for the kids to play on. I'll post a pic when I can. Had to drill new holes for it is all. Even running same size pulley. Just have to make sure not in a high gear or floored on vari drive when trying to climb hills or such.
tractors with push mower engines Sig115PROJECTS:
tractors with push mower engines Sig214tractors with push mower engines Sig314
Bio Hazardra
Bio Hazardra
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 14th 2016, 9:13 pm
that would be a nice idea:
putting a stock 5 speed or 6 speed in a vari-drive tractor with a push mower engine
simple, cheap
i might do that if i get another MTD sometime
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 14th 2016, 9:48 pm
I got a riding mower with the vari-drive and changed the f/n/r for a 6 speed. The transaxle pulley is about 4 inch with the original engine pulley, and an 8 hp Briggs on it too for the pull start. Goes real slow, I used to use it for cutting grass. I had to slow it down because the 8 hp wasn't strong enough to cut the grass. Works good for cutting the grass now that it can go real slow.
Yah, so I got 36 forward gears and 6 reverse gears on it, LOL.
TheGreenHornet
TheGreenHornet
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 14th 2016, 10:21 pm
I almost bought a sears suburban. it was a 70, if i recall correctly. the original engine had gone, due to neglect. it had a single cylinder, not sure who made it. not an onan. But somebody had repowered it with a 3hp briggs single and slightly changed the gearing. He used it as a utility tractor, said it would pull his full size 2 ton utility truck. Kinda impressive. but you can do a lot with gearing. He said it was slower than watching a non turbo 7.3 diesel with a manual accelerate, but man it could pull. in the end, he would not budge from his price of 200 bucks, which in my opinion is too much for a rusty, beaten up tractor. The entire thing looked like it had never been kept under a roof its entire life. Too bad, i like me a good ol sears....
Anyway, thats just my two sense lol!
Bio Hazardra
Bio Hazardra
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 8:16 am
that sounds like it would be fun to putt around on lol
i tried putting a 8 hp on a 38 inch craftsman 2 and it didnt turn the deck good. it would ride a wheelie but as soon as the blades were engaged it would bog down a lot :/ i would have thought it would have worked on it but it didnt
ive got a 8hp but to me a briggs push mower engine is a lot more reliable than a riding mower engine for whatever reason :/
thats why i prefer Kohler over briggs
briggs and Tecumseh are about on the same level for me
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 11:40 am
Here is the one I mentioned above.
tractors with push mower engines IMG_20161015_081449488_zpsyvvyiobn
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 12:54 pm
Nice mower man. Does it do stock speed?
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 2:29 pm
It does a little over 6mph.
Bio Hazardra
Bio Hazardra
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 2:32 pm
omg dude xD
that thing looks awesome
i hope i come across another MTD sometime so i can tranny swap it and do something like this lol
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 4:19 pm
You could probably push more than 6mph out of her. Mower looks really cool
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 4:25 pm
I was thinking the same. Swap a couple pulleys and it would be faster. It's good for now.
PostSubject: Re: tractors with push mower engines   tractors with push mower engines Icon_minitimeOctober 15th 2016, 5:25 pm
Yeah, I think that there is a place for small engines in the off road mower world. Too often you see those big 24hp V-twins installed when you're never going to use all that power. A small engine also means higher fuel economy.
» My restored push mower.
» push mower engine conversion/ rev limiter
» Some useful tow tractors, scoops, tow dollys, tracked tractors, and other concepts I have come up with
» B&S V-Twin 24 Hp Push rod problem
