 push mower engine conversion/ rev limiter
jsisti845
jsisti845
push mower engine conversion/ rev limiter Empty
PostSubject: push mower engine conversion/ rev limiter   push mower engine conversion/ rev limiter Icon_minitimeJune 30th 2014, 9:16 pm
im not sure if im the first person to do this or not but I have converted my briggs 6.75hp push mower engine for my mini rally mower. surprisingly it has a 1 in shaft. I have removed the engine break (this is used to shut off the engine when you let go of the lever on the mower the break engages).I bypassed the govoner but don't worry I have used the govoner linkage for a rev limiter. I mounted the coil wire behind the govoner linkage and put a return spring on the govoner. so when the engine over revs the govoner arm pulls back and grounds out on the wire causing the engine to cut out. I like this set up because its unique and I just like the sound of a limiter. tell me what you guys think positive or negative I don't care.
jsisti845
jsisti845
PostSubject: Re: push mower engine conversion/ rev limiter   push mower engine conversion/ rev limiter Icon_minitimeJune 30th 2014, 9:25 pm
push mower engine conversion/ rev limiter 00711push mower engine conversion/ rev limiter 00810push mower engine conversion/ rev limiter 00910
engine break removed
push mower engine conversion/ rev limiter 01010push mower engine conversion/ rev limiter 01110push mower engine conversion/ rev limiter 01210
PostSubject: Re: push mower engine conversion/ rev limiter   push mower engine conversion/ rev limiter Icon_minitimeJune 30th 2014, 11:04 pm
I saw someone do it on a 12hp flatty I think on youtube. Pretty cool having the rev limiter chatter.
jsisti845
jsisti845
PostSubject: Re: push mower engine conversion/ rev limiter   push mower engine conversion/ rev limiter Icon_minitimeJune 30th 2014, 11:30 pm
ya it sounds pretty cool I think it would sound better with a long straight pipe.
jsisti845
jsisti845
PostSubject: Re: push mower engine conversion/ rev limiter   push mower engine conversion/ rev limiter Icon_minitimeJuly 1st 2014, 11:08 pm
only one reply???? I want to hear some feed back!
fast adam
fast adam
PostSubject: Re: push mower engine conversion/ rev limiter   push mower engine conversion/ rev limiter Icon_minitimeOctober 25th 2014, 9:17 am
so why do you want a rev limiter, what is the engine going into?
Carshowkid
Carshowkid
PostSubject: Re: push mower engine conversion/ rev limiter   push mower engine conversion/ rev limiter Icon_minitimeOctober 25th 2014, 10:48 am
Cool thing you did there... Just want the mower to sound like a chevy ls? And just rev limit all the time... Lol!
» My restored push mower.
» A new idea for a riding mower engine?
» Leaf springs on front mower axle conversion: How to!
» Mower boat engine
