| Peerless Brake Idea | |
WilliesBuilds Member
Age : 29 Join date : 2013-06-19 Points : 4566 Posts : 329 Location : Florida
| | | | crazykid1994 Established Member
Age : 30 Join date : 2013-03-18 Points : 4922 Posts : 618 Location : loxahatchee, florida
| Subject: Re: Peerless Brake Idea October 2nd 2013, 9:12 pm | |
| weld it? or bolt it on. obviously with the size difference welding is your best bet | |
| | | mudmonkey06 Member
Age : 28 Join date : 2013-03-18 Points : 4591 Posts : 327 Location : Rindge, NH
| Subject: Re: Peerless Brake Idea October 2nd 2013, 9:31 pm | |
| welding might be the best thing to do just make sure its centered | |
| | | Doc Sprocket Site VIP
| Subject: Re: Peerless Brake Idea October 2nd 2013, 9:37 pm | |
| Bolt if you can, weld if you must. Just get that sucker concentric! | |
| Subject: Re: Peerless Brake Idea October 2nd 2013, 9:49 pm | |
| ok I will take it tmrw to my job and see if the guys can help me out 3 heads are better than one lol . ill keep you guys posted | |
| | | mudmonkey06 Member
| Subject: Re: Peerless Brake Idea October 3rd 2013, 5:54 am | |
| so what are you doing with this. obviously its a brake upgrade but how are you doing it | |
| Subject: Re: Peerless Brake Idea October 3rd 2013, 8:19 am | |
| this will be going on my murray widebody im building right now I found a hydro caliper and I just need to fix my master cylinder but I have those parts just brainstormin now | |
| Subject: Re: Peerless Brake Idea October 3rd 2013, 8:20 am | |
| if I can mount it on the little disk then its going on the stock location on the transaxle | |
| | | mudmonkey06 Member
| Subject: Re: Peerless Brake Idea October 3rd 2013, 10:29 am | |
| - WilliesBuilds wrote:
- if I can mount it on the little disk then its going on the stock location on the transaxle
thats cool are you going to run it as a hand or foot brake | |
| Subject: Re: Peerless Brake Idea October 3rd 2013, 1:32 pm | |
| im thinking hand brake but id love a foot brake but idk where to put It | |
| Subject: Re: Peerless Brake Idea October 3rd 2013, 2:40 pm | |
| I'm imagining the floorboard to be a good starting point... | |
Age : 49 Join date : 2012-04-23 Points : 5698 Posts : 1091 Location : Galion, OH
| Subject: Re: Peerless Brake Idea October 3rd 2013, 7:36 pm | |
| On our tractors, we put our brake pedals on the same side as the gas, just further back... it seems like it would be awkward, but it's pretty easy to get used to. | |
| Subject: Re: Peerless Brake Idea October 3rd 2013, 7:50 pm | |
| Makes sense, really. Assuming you have a left-foot clutch and a right foot throttle- it stands to reason you'd put the brake with the throttle. It's pretty common to need to operate the clutch and brake at the same time, less common to have to work the throttle and brake without the clutch... | |
| Subject: Re: Peerless Brake Idea October 4th 2013, 8:17 am | |
| yeah that's exactly my worry but ive done it before and havent had problems but I want to mount the pedal and make it look good last time I did it was just an ugly quick fix , but atleast it worked. | |
