 Hand brake
Cr8zyB0b
Cr8zyB0b
Hand brake  Empty
PostSubject: Hand brake    Hand brake  Icon_minitimeApril 16th 2013, 6:06 pm
I am building a rear engine swap/mud mower and it goes pretty quick as the trails we use are around 4 miles away thou woods and I was using standard brakes but it comes to a complete stop before I finish shifting so I disconnected the brakes and was wondering if it is possible to make a hand brake to skid the rear end like in a car but also have foot brake as well..
Hand brake  Empty
PostSubject: Re: Hand brake    Hand brake  Icon_minitimeApril 16th 2013, 6:10 pm
If you add another pedal you can make a linkage to that. Fearlessfront uses a cable brake hooked up to his shift knob, so you could do that as well.
Hand brake  Empty
PostSubject: Re: Hand brake    Hand brake  Icon_minitimeApril 17th 2013, 9:10 am
Me and my friends have our brakes set up on a separate pedal... a handle wouldn't be too tough to add I don't think. Maybe you could also make it so the linkage has a slide on it so the handle doesn't move with the pedal.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
WellThatsSurprising
WellThatsSurprising
Hand brake  Empty
PostSubject: Re: Hand brake    Hand brake  Icon_minitimeApril 17th 2013, 2:27 pm
To have two handles controlling one brake you could just use a splitter, they use them on BMX bikes.
Hand brake  Pr868010
Hand brake  Empty
Hand brake
» What's everyone running for brakes?
» Trans Axle Input Shaft Brake (Pinion Brake)
» Brake idea, using existing brake.
» Can anyone help me about hydrolic brake?
» Clutch and Brake
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
