I'm lookin to change my stock brakes on my craftsman. anyone here have experience with any hydraulic systems from a go kart or mini bike ? I'm running larger tires on a stock transaxle with a 5" pulley.
Ford Boi uses cut down automotive brake pads in the stock caliper - he also slots the stock disc with a grinder - another member ( cant find the post) used automotive discs and calipers with an older chrysler master cylender on his tractor .
MSteele323 Member
Age : 50 Join date : 2010-04-09 Points : 5701 Posts : 267 Location : Little Rock Arkansas
i cant remember who on youtube but someone said that if you want to put hydro brakes on your tractor and the tranny isnt locked you have to put one on each side or something like that. ill look for it and get back to you if i can find it
with an open diff, if you lock one wheel, the other one tries to turn backwards. that makes for a sqirrley ride on loose stuff and a good way to snap an axle on hard pavement
CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5141 Posts : 241 Location : Winter Park
I couldent get my clutch brake to work after the pulley swap on my murray wide body. So i took the deck lift lever cut it down and made a hand brake between the shifter and seat. To use it just pill it up like a e brake. Used the stock brake. Works great. I dont have a good camra so cant do video but when i get one ill post one.
