| I now have brakes...... | |
Shawn1750 New Member
Join date : 2012-01-22 Points : 4707 Posts : 17 Location : Oregon
| Subject: I now have brakes...... January 29th 2012, 8:33 pm | |
| Sure is nice to be able to slide to a stop!
I've seen many of you ask how to get brakes for your tractor..... Here's what I did. Using a cut off saw, I grabbed a few disc brake pads from my mechanic neighbor and simply separated the pad material from the metal backing. Once separated, I simply used the old brake pad as a pattern, and traced it on the new brake pad material. I used the same cut off wheel that I use for metal and cut out the new brakes! A little shaving here and there to get them to fit, and I can stop with the best of them!!
Shawn | |
| | | Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5355 Posts : 170 Location : Ontario Canada
| Subject: Re: I now have brakes...... January 29th 2012, 9:12 pm | |
| thats probably the best material for that, i tried to use a cut down pad from a bicycle but it didnt want to grab very much | |
| | | dagr8tim Member
Age : 48 Join date : 2012-01-01 Points : 4941 Posts : 194 Location : Columbus, Oh
| Subject: Re: I now have brakes...... January 29th 2012, 9:39 pm | |
| Awesome idea.
My only worry is that the automotive break material would wear out your break disk. Assuming that the brake disk on a tractor isn't made of the same quality steel as a brake rotor. | |
| | | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4936 Posts : 208 Location : Tennessee
| Subject: Re: I now have brakes...... January 30th 2012, 1:22 am | |
| Vehicle brake material works great for tractors, just be sure to wear a mask when cutting it... | |
| Subject: Re: I now have brakes...... March 7th 2012, 7:10 pm | |
| - Shawn1750 wrote:
- I'll keep you posted!!
S So far so good! No abnormal wear detected yet!! | |
| Who is online? | In total there are 75 users online :: 0 Registered, 0 Hidden and 75 Guests
