| Disc brakes? | |
Hillbilly Homer Member
Join date : 2012-04-22 Points : 4840 Posts : 197 Location :
| Subject: Re: Disc brakes? July 14th 2014, 10:38 pm | |
| Guess they are for a bicycle or something right? No, haven't tried them, but I did put disk brakes on my machine. I don't see why they wouldn't work ok for a newer lighter mower though. Lincoln continental rear caliper, unknown rear rotor. | |
| Subject: Re: Disc brakes? July 14th 2014, 10:56 pm | |
| Yeah the avid bb7 is made for mountain bikes. ...But i like your idea better!... P.S. Nothing i get on is lighter!! | |
| Subject: Re: Disc brakes? July 15th 2014, 9:57 pm | |
| The thing I would do different is to have some more leverage with my brake pedal. Used a master cylinder from a jeep grand cherokee. Pedal I made is around a foot long and pushes on the master cyl not quite in the middle of the pedal from where it pivots at the bottom. Three or four inches higher on top would make it much easier to apply the brakes I think. | |
| | | Doug Site Owner
| Subject: Re: Disc brakes? July 15th 2014, 10:20 pm | |
| Bike brakes wont hold up, they are way too thin and the calipers are way too small, youll be replacing rotors and pads all the time. Best bet is to buy a kart setup or use a band brake. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4419 Posts : 491 Location : Index, Washington
| Subject: Re: Disc brakes? July 15th 2014, 11:06 pm | |
| - mr.modified wrote:
- The thing I would do different is to have some more leverage with my brake pedal. Used a master cylinder from a jeep grand cherokee. Pedal I made is around a foot long and pushes on the master cyl not quite in the middle of the pedal from where it pivots at the bottom. Three or four inches higher on top would make it much easier to apply the brakes I think.
I made three marks/ Red, yellow, green. If you put the master cylinder at the red mark you will have to push the pedal the hardest to get the most braking power. If you put the master cylinder at the green mark, you will have to push the pedal the least hard, to get the most braking power. | |
| Subject: Re: Disc brakes? July 15th 2014, 11:39 pm | |
The petal arm on most vehicals is probably 2 feet long, so thats a good amount of leverage, plus you dont have a booster. | |
| Subject: Re: Disc brakes? July 16th 2014, 1:21 am | |
| ...Thank you all... - Doug Fackler wrote:
- Bike brakes wont hold up, they are way too thin and the calipers are way too small, youll be replacing rotors and pads all the time. Best bet is to buy a kart setup or use a band brake.
i was thinking rotor would be pretty flimsy. | |
| | | | | Disc brakes? | |
| Who is online? | In total there are 65 users online :: 0 Registered, 0 Hidden and 65 Guests
