| 3/4 inch disc brake | |
arild365 Member
Age : 29 Join date : 2010-02-11 Points : 5808 Posts : 320 Location : Canada, BC
| Subject: 3/4 inch disc brake May 26th 2010, 7:57 pm | |
| hey guys im having trouble finding a disc brake that will fit a 3/4 inch shaft. looked on ebay and google and i couldnt find one. If any of you find something like this let me know(btw there mostly 1 inchers) | |
| | | Ropertractor14 Member
Age : 110 Join date : 2010-02-23 Points : 5466 Posts : 84 Location : Nova Scotia, Canada
| Subject: Re: 3/4 inch disc brake May 26th 2010, 8:07 pm | |
| I also had trouble finding one. Ended up making the disk on a lathe out of a piece of plate and buying a 3/4" weld-in hub for a pulley to use as the center. | |
| | | arild365 Member
| | | | Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6215 Posts : 779 Location : Angus, Scotland
| Subject: Re: 3/4 inch disc brake May 27th 2010, 11:59 am | |
| Yeah this is something I need to work on too! Dammit, why didnt peerless plan for their rear ends to be used for off roading/racing perposes! | |
| | | noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5368 Posts : 252 Location : DFW Texas
| Subject: Re: 3/4 inch disc brake January 14th 2011, 6:39 pm | |
| you can buy keyed spacers that go on a 3/4 axle and will bump it up to a 1 inch so you can put on your brakes. i forgot what there called but ill try and find a link for you http://www.bmikarts.com/item/3-4-Conversion-Bushing-6498 kinda what i was talking about. it goes from 3/4 inch to 1 1/4. i know theres more hubs for 1/4 inch than a 3/4 inch
Last edited by noledroByrreK on January 17th 2011, 12:58 am; edited 1 time in total | |
| | | redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6371 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: 3/4 inch disc brake January 14th 2011, 6:50 pm | |
| hey type in gokartparts.com and a green and white website should come up and im almost posative they have a hube for a 3/4 inch axle for 15$ then you can buy a disc to fit the hub for like 15$ hope that helps | |
| | | FOSWMT Member
| | | | Sponsored content
