 how to add brakes???
greener179
crazykid1994
6 posters
crazykid1994
crazykid1994
how to add brakes??? Empty
PostSubject: how to add brakes???   how to add brakes??? Icon_minitimeJune 21st 2013, 7:00 pm
how do i add brakes to my transaxle? i originaly bought it and it didnt have brakes on it on the mower. previous owner took everything apart. so i dont have the stock brake setup
how to add brakes??? Transa10
greener179
greener179
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 21st 2013, 7:03 pm
the little shaft sticking out the one sidein the front of the tranny is where stock brakes go you should be able to find a caliper and brake disc on ebay for fairly cheap.
crazykid1994
crazykid1994
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 21st 2013, 7:58 pm
i dont know the model for my transaxle. their is no label on it. :/ i have another transaxle. its a hydro. do you think the brake should swap from that one?
motorizedeverything
motorizedeverything
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 21st 2013, 8:24 pm
no you can not change out the brakes with the hydro
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 21st 2013, 8:25 pm
Doesnt hurt to try. I think the calipers are made the same. Otherwise it gets very expensive.
crazykid1994
crazykid1994
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 21st 2013, 8:28 pm
hmmm ok ill try and swap it first. if not ill try and modify a mechanical brake mount to my frame
crazykid1994
crazykid1994
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 21st 2013, 8:50 pm
i actually have 2 transaxles to try the brakes from hopefully 1 works
crazykid1994
crazykid1994
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 23rd 2013, 10:14 pm
well it works but i need better brakes and a way to have a seperate pedal or lever for my brakes
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 8:47 am
This thread should be moved here ->  https://www.atltf.com/f40-brake-support
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 11:43 am
here is how mine is set up, i got a caliper and rotor off of a pocket bike i had and took the factory lawnmower rotor and bolted it to the new rotor, then i made a bracket to mount the new caliper to and added a bicycle brake handle to the floorboard. heres a few pics.
how to add brakes??? Mowerb13
http://www.lastdropgarage.com
crazykid1994
crazykid1994
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 5:32 pm
yea im debating on doing that with a mechanical brake seeing your picture and maybe a bicycle handle on my shifter
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 9:00 pm
Ya I like the idea of the handle on the shifter better than mine
crazykid1994
crazykid1994
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 9:54 pm
well im putting a real gas pedal on my mower. so i wouldnt have room anyways. plus it will add leverage to the shifter
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 10:04 pm
Ya it might get a little sketchy when u accidentally hit the gas instead of the brake
crazykid1994
crazykid1994
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 10:20 pm
haha yea. i just hope having a gas pedal works out how i want it. im tired of the hand throttle
PostSubject: Re: how to add brakes???   how to add brakes??? Icon_minitimeJune 24th 2013, 10:24 pm
Ya it gets old going one speed, and I've seen the gas pedals work before so you should be good
» I now have brakes......
» the trail tractor
» How do you set up after market brakes?
» Disc brakes?
» What's everyone running for brakes?
