| Clutch and Brake | |
+5CornishMorgan Hillbilly Homer boggo CityRedneck CraftsmanKid1 9 posters | Author | Message |
CraftsmanKid1 Member
Join date : 2012-06-22 Points : 4584 Posts : 26 Location : Titusville Pa
| Subject: Clutch and Brake July 3rd 2012, 10:55 pm | |
| is there a way i could make the clutch and the brake separate peddles instead of when i just push the clutch pedal it acts as a brake | |
| | | CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5146 Posts : 241 Location : Winter Park
| Subject: Re: Clutch and Brake July 4th 2012, 3:41 am | |
| Just be lucky you have brakes. I have none, and I would believe you could if you looked at some fab work | |
| | | boggo Member
Age : 29 Join date : 2010-08-22 Points : 5286 Posts : 64 Location : australia, victoria
| Subject: Re: Clutch and Brake July 4th 2012, 6:18 am | |
| yes dude there is a possible way, also depends on the gearbox type, the brake workings and linkages and so on. on mine im gonna try to disconnect the brakes for the clutch peddle and run a bike hand brake lever and cord to the puller mechenisum or how ever u spell it | |
| | | Hillbilly Homer Member
Join date : 2012-04-22 Points : 4842 Posts : 197 Location :
| Subject: Re: Clutch and Brake July 4th 2012, 10:49 am | |
| well i want to make it so i can shift while im still driving instead when i hit the peddle it stops then i shift and i dont want that i want it like a truck almost also i have no idea what my trans is my tractor is a Craftsman LT4000 its a 6 spd manual with a 12.5 hp tecumseh | |
| | | boggo Member
| Subject: Re: Clutch and Brake July 21st 2012, 6:05 am | |
| ok my brake setup i did works good! i did it now the clutch only works as a clutch only, the brake is on its on lever that i pull like a hand brake in a car, works really well! ill post a pic when i can. | |
| | | CornishMorgan Member
| Subject: Re: Clutch and Brake July 21st 2012, 9:28 am | |
| - boggo wrote:
- ok my brake setup i did works good! i did it now the clutch only works as a clutch only, the brake is on its on lever that i pull like a hand brake in a car, works really well! ill post a pic when i can.
That's interesting, never thought of doing the brake on a hand lever. Can you post a pic when you have a min? | |
| | | boggo Member
| | | | W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5253 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Clutch and Brake July 22nd 2012, 1:21 am | |
| I know the 1998 John Deere STX38 has separate brake and clutch pedals, I'll try to take pics of it tommorow if I have time. | |
| | | | boggo Member
| | | | TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5703 Posts : 1091 Location : Galion, OH
| Subject: Re: Clutch and Brake July 23rd 2012, 10:10 am | |
| We don't use the stock brake anymore, but our brake pedal setup has not changed much since we did. We took the brake rod off of the clutch rod, and installed a separate pedal on the right foot board. We just took a simple piece of flat stock steel, bent at a right angle to make something you can hit with your foot, that goes through the foot board and pivots on a bolt we put through the frame. The brake rod is connected to the bottom of the "pedal's" arm, and we attached a spring to pull it back when you take your foot off. This was one of the easier, and most useful mods we did. We have since upgraded the pedal's design and angle, but it has stayed fundamentally the same since we came up with it. | |
| | | boggo Member
| Subject: Re: Clutch and Brake July 24th 2012, 5:51 am | |
| yer, your ideas are better but i dont mind mine as i had no brakes on the mower since i changed the pulley, i can pull i nice skid on the road with my brakes now XD | |
Age : 29 Join date : 2011-08-04 Points : 6402 Posts : 1434 Location : east dublin georgia
| Subject: Re: Clutch and Brake July 24th 2012, 2:46 pm | |
| my honda came with seperate pedals, one for the brake and one for the clutch if you press the brake it also engages the clutch its a good system
| | | BatTractor2012 New Member
Age : 32 Join date : 2012-08-11 Points : 4489 Posts : 2 Location : Charleston SC,
| Subject: Re: Clutch and Brake August 11th 2012, 11:54 am | |
| I wanna join the Mower Cycle Gang... aka the "Mowrons!" | |
| Who is online? | In total there are 89 users online :: 0 Registered, 0 Hidden and 89 Guests
