ahhhh damn bud if its shooting full out like that (happend before) its the fuel pump i highly recommend changing the oil and rebuilding the fuel pump then install a fuel shut off valve because these engines have pressure when tured off so the fuel pump keeps pumping fuel in
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
I clamped the fuel lines for a while with my carbs but over time it wore it down and cut the line. I got a fuel cut off switch from tractor supply for like 8 dollars (I think thats the cheapest I have saw) It is a lot of money for something like that, but its totally worth it.
Age : 30 Join date : 2013-03-18 Points : 4922 Posts : 618 Location : loxahatchee, florida
The shut-off valve is a bandage. What really needs attention is the float/fuel inlet needle and valve assembly. Rated popoff pressure is 5psi. Fuel pump rated pressure is about 1.5psi while running. There's no reason to need that shutoff valve to keep from flooding the cylinders/crank case.
So I'm probably gonna go a different route on the patriot it is gonna become a drag mower, as much as I hate lowering stuff ima gonna go ahead and do it! Thanks alot pro lol
look up transaxle flip and C notching frames... rather simple, and would do the job... and btw - thanks for rubbing in the one that got away by 20 minutes lol
