| Murray stamped frame build "THE PATRIOT" | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
| Subject: Murray stamped frame build "THE PATRIOT" September 10th 2013, 4:09 pm | |
| Alright so I've had this old Murray stamped frame for a little while now and just yesterday I finally got it running. It has a 19.5hp briggs opposed twin on it and a 5spd transaxle right now it goes about 15 cause it had a 3in on back and 3 on front. It may be getting a 6in front pulley and a 1 in or 3in rear. It will eventually become a military themed rat rod type mower with olive drab green and a white star or a deer skull on it not sure yet. I got this thing for 10$ from my buddy along with about 5 others. I got the name "THE PATRIOT" from promethiusedi. So here's some pics. This when I got it I will get some more pics up later
Last edited by k2500life on September 10th 2013, 6:11 pm; edited 1 time in total | |
Age : 30 Join date : 2013-03-18 Points : 4922 Posts : 618 Location : loxahatchee, florida
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 10th 2013, 4:37 pm | |
| nice. i wish i could find an engine like that. or stronger. lol. be careful about that stamped frame. should probably add some bracing to it | |
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 10th 2013, 5:23 pm | |
| ive heard that some of the bigger engines have somewhat of a compression release built in when your starting them. i may be wrong though. haha.
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 10th 2013, 8:39 pm | |
| I took it for a ride down the road and it ran like poop and wouldn't stay running without me full force pulling the choke and does anyone know the air fuel mixture for the 19.5? | |
MowBandit Member
Age : 28 Join date : 2013-03-16 Points : 4746 Posts : 477 Location : Haddock,Georgia
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 11th 2013, 1:45 am | |
| had the same problom for the last few days i bought a new carb and kept doing it replaced the vacume line for the fuel pump solved my probloms | |
Doc Sprocket Site VIP
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 11th 2013, 8:53 am | |
| - k2500life wrote:
- I took it for a ride down the road and it ran like poop and wouldn't stay running without me full force pulling the choke and does anyone know the air fuel mixture for the 19.5?
That indicates that you're running lean. There are many possible problems, but they all amount to the same thing. Not enough fuel for the air going in. Check fuel delivery, carb tuning, pump and pump actuation, cracked vacuum line to the pump, etc. Do you have any idea if your carb has a fixed main jet, or an adjustable main? A few pics of the carb would help, but I suspect it's NOT adjustable. | |
cumminsbayou Member
Age : 27 Join date : 2011-11-04 Points : 5018 Posts : 232 Location : fairhope Al.
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 17th 2013, 5:37 pm | |
| What type of compression does it have? May be just cut the gas off to it. Can you show more of the flappers? I was gonna buy some but there to much at tractor supply. | |
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 19th 2013, 9:11 pm | |
| So I get it running again and I pulley swapped it with a 7 in front 3 in rear it goes about 30 with a burnt up old belt so I need a new belt | |
MowBandit Member
| Subject: Re: Murray stamped frame build "THE PATRIOT" September 20th 2013, 1:16 am | |
| ahhhh damn bud if its shooting full out like that (happend before) its the fuel pump i highly recommend changing the oil and rebuilding the fuel pump then install a fuel shut off valve because these engines have pressure when tured off so the fuel pump keeps pumping fuel in | |
