 Joey's Monster Murray Build [2017 Build-Off Entry]
AlaskanJoe907
9 posters
AlaskanJoe907
Joey's Monster Murray Build [2017 Build-Off Entry] Empty
PostSubject: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeFebruary 1st 2017, 11:03 pm
This is my first time entering in a build-off so here goes it. Here's my build plans and a few pictures of the Murray. Joey's Monster Murray Build [2017 Build-Off Entry] 14508511 Joey's Monster Murray Build [2017 Build-Off Entry] 16425310 Joey's Monster Murray Build [2017 Build-Off Entry] 16468910
AlaskanJoe907
PostSubject: Joey's Monster Murray Build   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeFebruary 1st 2017, 11:08 pm
Some pictures of what ive done so far and some of the other parts, Pillow block bearings for extending the drive shaft, the transaxle, Joey's Monster Murray Build [2017 Build-Off Entry] 16441310, Joey's Monster Murray Build [2017 Build-Off Entry] 16466810
it has custom radius arm front suspension, Joey's Monster Murray Build [2017 Build-Off Entry] 15403612
Joey's Monster Murray Build [2017 Build-Off Entry] 15843912
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeFebruary 2nd 2017, 8:19 am
Looks like a lot of builds incorporating suspension this year. Good luck!
AlaskanJoe907
PostSubject: Joey's Monster Murray Build   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeFebruary 12th 2017, 7:32 pm
A little up date, I'm getting the rear end lifted, 2 inches shorter than the rear and getting every thing mocked and tacked up and then fully weldedJoey's Monster Murray Build [2017 Build-Off Entry] 16754210
Joey's Monster Murray Build [2017 Build-Off Entry] 16754410
Joey's Monster Murray Build [2017 Build-Off Entry] 16736010
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeFebruary 16th 2017, 11:42 pm
hey man, how is this coming along? if you need any advice or help with ideas shoot me a message, ive got experience with lifted mowers, and modding them in general, i like to see other people build lifted ones
AlaskanJoe907
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeFebruary 18th 2017, 4:02 pm
Only problem That's holding me back is my Pulley on my transaxle it does not want to come off, tried wax ,WD-40, brake cleaner, still need some help
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeFebruary 19th 2017, 8:20 pm
Might have to split the case, remove the retainer clip for the gear and pull the shaft. With it out of the case, you could put it in a vise or a pipe to hold the pulley and nail the shaft out of it. But then again, you have a center bolt holding the case together along with the outer bolts. Would be hard to just pull on the pulley till the clip that holds the gear on inside pops off, but is doable.
AlaskanJoe907
PostSubject: Joey's Monster Murray Build   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeMarch 13th 2017, 1:22 am
Sorry I haven't been in a while, with Life and school, haven't had much time to work on the Build Off. Soon will post some pictures.
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeMarch 13th 2017, 9:12 am
You have plenty of time, and school and life are pretty important!
Joey's Monster Murray Build [2017 Build-Off Entry] Sig115PROJECTS:
Joey's Monster Murray Build [2017 Build-Off Entry] Sig214Joey's Monster Murray Build [2017 Build-Off Entry] Sig314
Cityslickerbuilds
Cityslickerbuilds
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeMarch 31st 2017, 8:44 pm
Let me know if you need help with the Beer cup holder. I am pretty good at making those.
AlaskanJoe907
PostSubject: Joey's Monster Murray Build   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeApril 26th 2017, 12:08 am
how'd you make your beverage holder
AlaskanJoe907
PostSubject: Joey's Monster Murray Build   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeApril 26th 2017, 12:26 am
Did a little work on the mower, Joey's Monster Murray Build [2017 Build-Off Entry] 18110610, I stripped her down to her frame to start working on the clutching and jackshaft. Joey's Monster Murray Build [2017 Build-Off Entry] 18142710, removing unnecessary wires. Joey's Monster Murray Build [2017 Build-Off Entry] 18143210, moved the clutch assembly forward about 6 '', to make room for the jackshaft.
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeApril 26th 2017, 8:55 am
This build is gonna look MEAN! I'm diggin' it hahaha.
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeApril 26th 2017, 9:09 am
Is that piece the bearing is bolted to stainless? Hope you have a MIG welder for that stuff. Lookin awesome! Making me wanna do a lifted mower.
Cityslickerbuilds
Cityslickerbuilds
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeApril 26th 2017, 12:56 pm
Went to home depot and bought a pvc pipe cap and a section of pipe.cut the pipe to desired length, then push it into the cap. Drill a hole in the center of cap and bolt in place.
AlaskanJoe907
PostSubject: Joey's Monster Murray Build   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeMay 22nd 2017, 2:46 am
So the reason why I haven't posted anything in a while is because I decide to cut out the radius arm suspension, due to every time I would steer the axle left or right, the axle would tilt forward or back. So now I plan on doing a tall Independent suspension in the front for better cushion going over bumps. If I can find a front end of a 4 wheel such as an old Polaris trailboss, which would be nice, I could use it and weld it to the existing mower frame.
PostSubject: Re: Joey's Monster Murray Build [2017 Build-Off Entry]   Joey's Monster Murray Build [2017 Build-Off Entry] Icon_minitimeDecember 2nd 2017, 1:33 am
I have unlocked your thread and moved it to the [ Lifted ] section, feel free to keep updating it.
» Black Horse Pike Monster [2017 Build-Off Entry]
» TheCollectors murray [2017 Build-Off Entry]
» bow tie mud guy thrasher build - build #1 [2017 Build-Off Entry]
» 2017 lawn tractor buildoff SPEEDSTER Dave 007 [2017 Build-Off Entry] [Finalist]
