| Murray Stamped Frame | |
+5Destructive RichieRichOverdrive AllisKidD21 darkside0914 Murraymountain 9 posters |
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4435 Posts : 2178 Location : North Carolina
| Subject: Murray Stamped Frame June 26th 2019, 9:12 am | |
| Hey guys, so this is "the guest mower" that I've been doing some work to to get it ready for the offroad trip... A stamped frame murray I got for free when I got the Craps-man. It had a rusted deck, and looked like it would never run again. After a few months of tinkering, turned out it needed a carb, a coil, a starter, a little electrical work, and some new front wheels. She's already undergone one motor swap, and now it has the awesome 14.5HP Briggs on it. I think a Peerles 930, which I don't like. It wont even pop a wheelie. Anyway, She's never run more than half way decent. She spits, farts, and misses every once in a while, so it probably needs a new carb. (I mean it did come of the Craps-man so of course it needs a new carb) It ain't very fast, and the pulley setup I was using just plain isn't gonna work. So, $40 later, I got 2 pulleys from TSC and hope I have a spare belt (I'll be putting them on sometime this week I hope). And I need to cut the turfs. Plus, the stupidness of how it was built causes the steering to lock up when your on an angle, so I need to cut what's getting in the way of the one rod setup out. Anyway, it never got it's own thread yet because it sits in the shed most the time. So after the mudding trip, back to the shed she goes. | |
2020 Build-Off Top 3 Winner
Age : 48 Join date : 2018-05-05 Points : 2989 Posts : 518 Location : S. Illinois
| Subject: Re: Murray Stamped Frame June 26th 2019, 12:51 pm | |
| never really cared for that model murray, but then until i got my widebody i ran nothing but old craftsmans and a montgomery ward i got a speeding ticket on | |
Age : 25 Join date : 2016-07-10 Points : 8590 Posts : 5190 Location : Ontario Canada
| Subject: Re: Murray Stamped Frame June 26th 2019, 12:52 pm | |
| Does that have one of those hoods that hinges at the back like an automotive deal? I always thought that was sorta neat. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Murray Stamped Frame June 26th 2019, 1:17 pm | |
| - darkside0914 wrote:
- never really cared for that model murray, but then until i got my widebody i ran nothing but old craftsmans and a montgomery ward i got a speeding ticket on
I like the looks of it. But I just like Widebodys better. - AllisKidD21 wrote:
- Does that have one of those hoods that hinges at the back like an automotive deal? I always thought that was sorta neat.
Yep! That's my favorite part about this machine. | |
| Subject: Re: Murray Stamped Frame June 27th 2019, 9:18 pm | |
| So, the steering problem... When the axle is articulated all the way up on the left side, it won't steer left because the white circle hits the blue circle in the butt, so I took the grinder to it. Got the pulley swap done. She goes pretty darn good. I'd say at least 15MPH. Also got the rear tires cut up and ready for mud. I'll get pics tomorrow. Ordered a new carb too. | |
Age : 22 Join date : 2016-10-29 Points : 7227 Posts : 4023 Location : Lewisburg, KY
| Subject: Re: Murray Stamped Frame June 28th 2019, 2:11 pm | |
| Nice rig. Gonna lock the 930? Steering is a pain. Always gotta clearance something for it | |
| Subject: Re: Murray Stamped Frame June 28th 2019, 7:54 pm | |
- Nice rig. Gonna lock the 930? Steering is a pain. Always gotta clearance something for it
Thanks! Right now I'm not, but maybe in the future. We'll see. Yep, always something. | |
| Subject: Re: Murray Stamped Frame July 3rd 2019, 9:56 pm | |
| Well, I've made plenty of progress this week! Got the carb installed, used gasket maker to hold the hood screws in, got a hood pin with a "nutish" screw thingy on it (forget what it's called), deep water tested it (should've gone deeper), and found out that it's just like FF's Murray, goes really really fast into the mud, and then just stops and spins LOL! Now I need to fix the parking brake, and the belt falls off every time you go down a steep hill or you press the clutch/brake. And, something that I could really care less about, but it knocks under a load. It's already had one motor swap, so if worse ever comes to worst, than I don't see any harm in a V-Twin... . Almost ready! Deep Water Test | |
Destructive Member
Age : 45 Join date : 2019-07-20 Points : 2025 Posts : 57 Location : King, NC
| Subject: Re: Murray Stamped Frame August 5th 2019, 9:29 pm | |
| So, I've been using it a lot lately. Only thing was a bad carb flood, had to go through everything to get it running again. Anyway, I decided to get this build finished up. Tomorrow I gotta make belt guides to keep the belt from falling off, and I need to fix the parking brake... She could probably use a new head gasket and belt soon too. But today, I added headlights and taillights, a seat spring (hopefully I can get another one for the other side), and Duct Tape to keep the + terminal of the battery from touching metal and shorting... Duct Tape (permanent I think...) Butt-saver... And headlights... Used the MM's. Taillights... One thing I like about the headlights... They glow back... It's absolutely AWESOME in the night! How I wired them... Makin' progress! | |
| Subject: Re: Murray Stamped Frame August 6th 2019, 7:56 pm | |
| It went from innocent fun, to frustrating to look at. The belt is done for, the seat spring didn't work out, the belt guides are useless, even managed to run it into a support beam at the shop and caused harm to the light lenses...
Anyway, I now need to re-think the drive system because the belt burns on literally everything it can touch, not to mention how much it falls off, get a new belt, new oil and head gasket, label the on/off switch for the headlights, maybe I will lock the transaxle, and it really needs front and rear mud flaps. But I want this project done and out of my way so Ima do what I have to get it done. | |
Destructive Member
| Subject: Re: Murray Stamped Frame August 7th 2019, 12:53 pm | |
| Im hoping that you have idea pop up on the drive belt that works wonders for you, because im glad someone else is in process of working on stamped murray. Mine has stock drive so I havent modded anything there yet to help. | |
| Subject: Re: Murray Stamped Frame August 7th 2019, 8:31 pm | |
| Huh. I'm kinda stumped right now. LOL. I want it done before the Mountain Murray gets back from the fab shop. Eventually it'll be finished. | |
Destructive Member
| Subject: Re: Murray Stamped Frame August 8th 2019, 10:15 am | |
| What pulleys/mods are you running compared to stock drive setup? | |
| Subject: Re: Murray Stamped Frame August 8th 2019, 10:57 am | |
| Well, lets see, a deck drive pulley from something in the front, and a 5" in the rear. That's my ratio... My clutch is stock besides adjusting it some, and replacing the plastic pulley with a steel TSC one, so it's pretty much the same as your clutch. But, all the pulleys are off. Here's a drawing of what I mean by off... Sorry for the strange background... So, as you can see, the pulleys are off, causing the belt to burn on all sorts of stuff... I also think this is the reason for the belt getting thrown. For one, the belt is burning on the brake pedal itself, 2nd, it burns on the shifter rod (the part that sticks out of the trans.)... But all pulley swapped murrays do. The reason I think the belt is off on the rear is because the C-clip broke (the one that holds the pulley from rubbing on the casing. I also saw sparks coming from that area when I watched a video of me popping wheelies). As for the front... I don't know what to do there... I'll try to get some pics of the actual drive line, I'll also upload the wheelie video so you can see the sparks. But the other issue, is that whenever you press the clutch, the belt loosens so much, it almost falls off. I'll try and get a video of that too. | |
| Subject: Re: Murray Stamped Frame August 11th 2019, 9:53 pm | |
| Welp, I remembered that the old JD deck had some good idler pulleys on it, so tomorrow, those will be transfered to the stamped frame. The head gasket and oil change is also not happening now, and the belt was too small by far. So, whenever I get the right belt, and get some rear mud flaps, and maybe throw some 16 inch front wheels on it, it'll be complete. In case you haven't watched the video, here's the front mud flaps... Here's what I did with those metal thingamajigerys... | |
Destructive Member
| Subject: Re: Murray Stamped Frame August 12th 2019, 8:19 pm | |
| Almost... Didn't have any time to tinker with it today... Had to get the Craftsman all finished up. Got a belt though, I'll find out if it's the right size tomorrow I guess.... | |
| Subject: Re: Murray Stamped Frame August 14th 2019, 3:30 pm | |
| Well, got a belt that fits! No way to stop when in gear except to either throw it in neutral or turn the key off, but it drives! Here's a video of me driving it... videoI also busted out the old amp meter so I could use it as a place to clamp my I-pod to since I added my Murray's old music system to it... New "Radio"And since I got tired of busting up the hood, I added a brush guard. it's the old frame to one of [url=amazon.com/Ezyroller-Ride-Toy-Classic-Scooter/dp/B07577K2KW/ref=asc_df_B07577K2KW/?tag=hyprod-20&linkCode=df0&hvadid=312127623820&hvpos=1o1&hvnetw=g&hvrand=760898958897646594&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9010337&hvtargid=pla-571039578195&psc=1][/url] that I used have... I'm also gonna add a cargo area in between the seat and steering column by putting a Craftsman battery box there... And I put my Murray's battery box in because I got tired of the battery flopping around in there and slicing wires... Comin' right along! | |
| Subject: Re: Murray Stamped Frame August 17th 2019, 5:28 pm | |
| Okay, got a cutting wheel for the angle grinder, so now I can make the cuts for the cargo box! I mounted it by drilling three holes where the wires would go, and just zip tied it in... Must say it fits quite nicely... Not much in it right now, buts stuff's comin'! And since we were headed to the fab shop anyway, I had them weld the mud flap bolts in... And this is the back light that the headlights give in the night.... It's pretty awesome! Now I just need some rear mud flaps and I can officially call this one complete! | |
| Subject: Re: Murray Stamped Frame August 27th 2019, 7:49 am | |
| Well, been working on this since Sunday afternoon... School takes up most of my time, but I'll have it finished tonight! So as you know the Craps-man is dead, so the body is now going to this... That's right, a body swap! It went from this: To this: So after cutting this out: I thought it'd look pretty good. It's not as high as it will really be in these pics, but it looks meant to be: Then the next day (yesterday), after removing the floorboards, I cut all those tabs out of the shifter's way: Then I cut a space for the clutch pedal: And then, after cutting the MO area out of the body and a little too much of it, I could fit the battery and the body in place permanently. I do wish there was more meat in the back, but it fits like it was made for it: Plenty of clearance: The front is mounted, but I'm still working on the rear, the seat is gonna give me some trouble if the shifter doesn't. I still have to remove the "CRAFTSMAN" stickers because, well, it's not a craftsman . I'll be using the original junk Murray floorboards. Anyway, it's comin' along great. I also plan on putting a rack on it now. | |
