 MTD trail build
George Gooding
6 posters
Go to page : 1, 2, 3, 4  Next
George Gooding
MTD trail build Empty
PostSubject: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 6:49 pm
MTD trail build 20180610
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 6:54 pm
Looks pretty neat. Do you have the cylinder head tins though? I wouldn't wanna run it for to long without them or the head won't be getting cooled very well.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 6:55 pm
What I've done so far
MTD trail build 20180611
MTD trail build 20180612
MTD trail build 20180613
MTD trail build 20180614
MTD trail build 20180615
MTD trail build 20180616
MTD trail build 20180617
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 6:58 pm
Going to have to source the cylinder head tins or fab some up.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 7:02 pm
Need input about the hood mounted carrier, does it look OK? Is it too long? Too tall? It's kinda mocked up at the moment.
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 7:09 pm
I would shorten it, and maybe lower it or the hood a little.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 7:16 pm
That's kinda what I was thinking. Lower it about 2 in and shorten it to the end of the hood, the top rails are aluminum and not sure how well my welder will do on in, I do have a spool of flux core aluminum welding wire tho.
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 20th 2018, 8:57 pm
yeah I agree with shortening the length and height of the hood rack.  Pretty handy to have depending on what you're doing with the machine.
George Gooding
PostSubject: Frame Bracing/support   MTD trail build Icon_minitimeJune 21st 2018, 1:16 pm
MTD trail build 20180619, need recommendations on bracing the frame, using it for pushing, pulling and trail riding (mud, rocks, hills and chat) sometimes while pulling a trailer
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 1:18 pm
Also using a front mounted winch
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 1:33 pm
I merged your new thread with this build thread, if you have any questions you can just ask them here instead of starting a different thread. Keeps things neater looking is all. MTD trail build 2731072446
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 3:01 pm
OK, thanks
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 4:40 pm
I'd reinforce the frame around the front axle, where you'd be mounting a bumper, and where the transaxle mounts.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 4:45 pm
What about the middle or is a slight amount of frame flex OK?
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 4:49 pm
I think a slight amount is okay, if the frame can flex a little bit it can take stress of other things like the front axle and trans, but maybe the better way to go is to add some cross members or reinforce it with c channel or angle iron.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 5:59 pm
Front axle will be articulated
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 6:01 pm
Okay then I'd consider reinforcing the pivot point if you're going to be doing to reinforcement work.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 7:00 pm
3/8 or 1/4 in plating? Was thinking 1/4" for the riser and 3/8" at the pivot
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 7:06 pm
3/8" plate seems like overkill a bit, I think 1/4" would be fine and plenty solid for sure.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 7:37 pm
OK, thank-you. I went to get the rear shocks & foot brake (for the throttle) off my 1980 Suzuki gs500 and found out someone broke into the garage and wiped it out. tubing, plating (steel and aluminum), my old motorcycle and both of my old lawn tractors.
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 8:20 pm
Cool, this is the same as my Budgie rig! You can check my Budgie thread if you want some inspiration for bracing the front end, i think i did a good job on mine.
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 21st 2018, 8:36 pm
I've been checking it from time to time
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 22nd 2018, 2:12 pm
Hey, do you have the seat for this?
George Gooding
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 22nd 2018, 2:27 pm
Yes I do, just don't know if I'm gonna reupholster it or go with a high backed upgrade
PostSubject: Re: MTD trail build   MTD trail build Icon_minitimeJune 22nd 2018, 2:31 pm
Can you get a picture of the bottom part with the tabs to go into the frame and what not? I don't have the seat for mine, I'd like to know what they look like so i can make one.
MTD trail build
Page 1 of 4Go to page : 1, 2, 3, 4  Next
» MTD Trail Runner Build.
» Lawn Flite Trail/mudder build
» CC's Ford YT16 Trail Mower Build
» ROPER Utility\Trail Build
» My trail/mudder lawnmower build
