 Can I guide my belt to one side? Without loosing to much power?
5 posters
Go to page : Previous  1, 2
Chopperhed
Can I guide my belt to one side? Without loosing to much power? - Page 2 Empty
PostSubject: Re: Can I guide my belt to one side? Without loosing to much power?   Can I guide my belt to one side? Without loosing to much power? - Page 2 Icon_minitimeMarch 26th 2013, 12:16 pm
another option is finding a Big #50 sprocket, and having it drilled to match the bolt pattern of the ATV sprocket, but that won't be cheap.
PostSubject: Re: Can I guide my belt to one side? Without loosing to much power?   Can I guide my belt to one side? Without loosing to much power? - Page 2 Icon_minitimeMarch 26th 2013, 1:01 pm
Yeah, but I can't find a racing clutch for the #50 size either. So guess I'm stuck on #40/41 size
PostSubject: Re: Can I guide my belt to one side? Without loosing to much power?   Can I guide my belt to one side? Without loosing to much power? - Page 2 Icon_minitimeMarch 26th 2013, 1:03 pm
Yeah i never seen racing cluch for #50 chain.
Chopperhed
Chopperhed
PostSubject: Re: Can I guide my belt to one side? Without loosing to much power?   Can I guide my belt to one side? Without loosing to much power? - Page 2 Icon_minitimeMarch 26th 2013, 1:56 pm
I had to run #40 from the clutch to the jackshaft
Its a Hilliard Extreme Duty clutch so it should hold up OK.
PostSubject: Re: Can I guide my belt to one side? Without loosing to much power?   Can I guide my belt to one side? Without loosing to much power? - Page 2 Icon_minitimeMarch 26th 2013, 2:04 pm
My plan was to have the clutch on the jack shaft.
PostSubject: Re: Can I guide my belt to one side? Without loosing to much power?   Can I guide my belt to one side? Without loosing to much power? - Page 2 Icon_minitimeMarch 28th 2013, 9:45 pm
They burn easy, so you better hit the pedal to the metal fast.
The toughest Hilliard is rated to 13hp I think.
» Project Spare Change aka Homemade Side by Side UTV
» i wantd side shift
» 15.5HP Kholer OHV side shaft engine
» v twin briggs side engine tin
