| Can I guide my belt to one side? Without loosing to much power? | |
Thunderdivine Veteran Member
| Subject: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 5:20 pm | |
| Like if this is the center of my tractor,
__________________|______________________ O O -------------------------------- O ----------------------------|------------------------------- could I guide the belt to one side, like the red O are? | |
gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5203 Posts : 392 Location : west chazy ny
Doug Site Owner
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 6:19 pm | |
| I dont think you would lose any power, so long your rear and front pulleys still have enough contact with the belt and its tense. If re-routing it deosnt let the belt touch the pulleys enough you will see more slippage if it gets wet. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Doug Site Owner
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 9:10 pm | |
| - Doug Fackler wrote:
- Yes.
I dont see how moving it to the one side would allow you to drop your seat further though. Your belt will still be under the seat. No it won't the seats a V kinda. And look at the pulley to the left, if the seat is into that one ur screwed that's why I need to break it off to one side. | |
Chopperhed Moderator
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 9:57 pm | |
| - Thunderdivine wrote:
- Guess I can even use a chain and sprocket or a toothed belt for that part. So it should work.
I wanna route it to one side so I can get the seat all the way down on the transmission, or very close abit in front of the axle. Personally, I'd get a set of #50 sprockets ground down to match #530 o-ring Motorcycle chain, pricey, but strong and would only need occasional lubrication. Chain, if properly maintained, doesn't slip even when wet. Tension is easier to maintain too. And if it gets bad enough, it can be shortened The oring chains are pretty well sealed, and a good chain wax can keep them in good running condition for a long time. | |
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 10:02 pm | |
The oring chains are pretty well sealed, and a good chain wax can keep them in good running condition for a long time. Yeah I'm considering a chain maybe a 50 chain? And a cvt or just a racing clutch | |
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 10:41 pm | |
- Yea since belts are based on they're enemy to work: Friction!
Do you know where you can get those toothed pulleys and belts, like a Harley's drive train size wise. I only know of harley drivs, and timing belts on cars easily. I'd imagine that local driveline shops (power transmission) would be able to supply industrial stuff. Anything Harley will be stupid expensive, but all the little cars nowdays are using toothed belts for timing chains, and the are pretty tough, if used correctly. Chain would still e cheaper, unless you have a source for free car parts. | |
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 11:04 pm | |
- Guess ima try chain. Surplus got the lot. To bad I already ordered pulleys earlier today
Ouch, that sux, post them locally. Knowing Norway, and being 1/4 Norwegian my self, There are bound to be a boatload of people there looking for parts for projects, | |
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 11:07 pm | |
Knowing Norway, and being 1/4 Norwegian my self, There are bound to be a boatload of people there looking for parts for projects, Yeah they won't stay unsold for long haha But what about gearing now then with some pulleys and some sprockets. My plan was 8" and 3or4" to the trans. | |
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 25th 2013, 11:33 pm | |
| It depends on what size you want.
Industrial #40 chain matches up to 400 series bike chain in regards to pitch
Industrial # 50 chain matches up to 500 series bike chain in regards to pitch
The big problem is the thickness of the srpocket, and the quality of the chain.
industrial sprockets, ie #40, #50 #60 etc. are much thicker than motorcycle stuff.
Second biggest rpoblem is finding bike style sprockets to fit standard shaft sizes.
Not easy.
Best option.
Buy high quality #50 sprockets to the size you need, to fit the shaft you need.. Buy a o-ring bike chain to the length you need. have the sprockets surface ground to the thickness needed to match a 530 bike sprocket.
Bike chains and sprckets are narrower/thinner than the industrial/ agricultural grade equivialents.
I'm running a #50 chain over a 530 sprocket, and the sprocket is way thinner than the #50 jackshaft sprcket.
Surface grinding is the best way to shave something like a sprocket down, without getting it hot enough to change the temper of the steel.
It's time consuming and expensive though, unless you have access to the equipment.
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 26th 2013, 8:38 am | |
- So do a 1:1 gearing with chain and have the actuall gearing with the pulley.
Nah I have access to lathes etc but not a precision grinder. Is it much difference in width? #50 sprockets are just about twice as thick as #530 atv sprockets | |
| Subject: Re: Can I guide my belt to one side? Without loosing to much power? March 26th 2013, 9:39 am | |
Nah I have access to lathes etc but not a precision grinder. Is it much difference in width? #50 sprockets are just about twice as thick as #530 atv sprockets Wow really, I looked at some pics of industrial sprockets, looks like they're flat like you said. But industrial chain was real cheap. | |
