 v twin briggs side engine tin
DiGiacomo
DiGiacomo
v twin briggs side engine tin Empty
PostSubject: v twin briggs side engine tin   v twin briggs side engine tin Icon_minitimeDecember 3rd 2023, 10:18 pm
Do i need to replace the tin on the sides of this v twin?? I'm installing twin stacks and this tin is a pain to deal with....I have open sides with an open frame built for the hood......I would think the open sides would be enough to keep the heat down???.....but you guys are the experts...... thanks for any opinions......
PostSubject: Re: v twin briggs side engine tin   v twin briggs side engine tin Icon_minitimeDecember 3rd 2023, 10:25 pm
The tins usually direct the air from the fan shroud to across the heads for cooling so for a machine that's not going to be traveling fast enough to air cool I'd say they're pretty important. You may be able to do a little bit of trimming though, can you post pictures so we can better advise?
My All Terrain Tractors:
DiGiacomo
DiGiacomo
PostSubject: Re: v twin briggs side engine tin   v twin briggs side engine tin Icon_minitimeDecember 3rd 2023, 11:38 pm
thanks for the info I'll do a little trim on the lower end flap.......that darn bolt on the bottom is the problem for me.....I will have to secure it somehow because the regulater is screwed onto it.....Ill see if i can get some pix when I finish the project......
TechnoChicken
TechnoChicken
PostSubject: Re: v twin briggs side engine tin   v twin briggs side engine tin Icon_minitimeDecember 4th 2023, 6:55 am
It also sounds like there is an exhuast being rerouted nearby, the tins should (In theory) also act like a heat shield.
DiGiacomo
DiGiacomo
PostSubject: Re: v twin briggs side engine tin   v twin briggs side engine tin Icon_minitimeDecember 4th 2023, 7:30 am
I think you guys sold me on the tin, I"l get it put back in place after i get the pipes positioned.......... thanks .....
MightyRaze and TechnoChicken like this post
» V-Twin Briggs exhaust glowing red on one side
» Briggs & Stratton Opposed Twin Engine Questions
» How to: Hook up a Diesel tachometer to a Briggs Opposed Twin or any Briggs with AC out.
» 15.5HP Kholer OHV side shaft engine
» Is it possible to do away with the linkage setup on the side of a briggs and run your throttle cable directly to your carb?
