| i wantd side shift | |
NickWiedenhoft Member
Age : 51 Join date : 2014-01-27 Points : 3968 Posts : 35 Location : Jackson,Tennessee
Age : 25 Join date : 2013-04-05 Points : 4928 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: i wantd side shift April 25th 2014, 10:31 am | |
Last edited by craftsmancole on April 25th 2014, 10:58 am; edited 2 times in total | |
Age : 27 Join date : 2013-03-18 Points : 7449 Posts : 3131 Location : raleigh nc
| Subject: Re: i wantd side shift April 25th 2014, 10:54 am | |
| I've always thought it was easier to just make a side shifter, but a frame chop isn't a bad idea at all. Are you plating it? | |
| Subject: Re: i wantd side shift April 25th 2014, 9:58 pm | |
| yep the inside and outside welded and the inside is plated.I did it this way because it took me way less time to do than making my own side shift which i was going to do untill the other craftsman feel in my lap. and the stock assembly works very nice. i have also gusseted the rear axle for strength. i did the rear gusset after Doc and I have had a few discussions about chassis flex | |
| Subject: Re: i wantd side shift April 25th 2014, 10:01 pm | |
| Im going to be running a 19 hp oppy for now and a peerless 205. future upgrades will be a 22 hp vtwin which i have now just have to see how well it runs | |
| Subject: Re: i wantd side shift April 25th 2014, 10:29 pm | |
| yep. as soon as i have funds and i find a good deal i want a kohler or a kawisaki. I'm almost afraid to even fire the tecumseh up.lol
| Subject: Re: i wantd side shift April 25th 2014, 10:33 pm | |
| yep. i might just make sure it runs and then sell it because i have a 19.5 oppy for a back up | |
| Subject: Re: i wantd side shift April 26th 2014, 12:11 am | |
| I haven't ever have had problems with tehcumsehs, in fact the racers really like their v twins, I own one. Run this one, I don't see that you would have any problem with it. I've seen people run the snot out if these un gov'd.i | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7284 Posts : 2914 Location : Ontario Canada
| Subject: Re: i wantd side shift April 26th 2014, 7:52 am | |
| Lookin' good, Nick! Run that Tec. It might surprise you. | |
| Subject: Re: i wantd side shift April 28th 2014, 2:37 am | |
| very true it could turn out to be a great motor. we will see eventually | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4202 Posts : 337 Location : Woodville Al
| Subject: Re: i wantd side shift April 29th 2014, 8:17 am | |
| Im about to redo my shift linkeg. Ill get some as i go. But i us the murray shift bracket upside down | |
