| | If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? | |
dwcopple Member
![If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? Empty](https://2img.net/i/empty.gif) | Subject: Re: If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? June 3rd 2014, 8:53 pm | |
| There is a difference, and i couldnt tell you what it is, but i know its by a few inches. If you have/ are going to a tractor supply, most have the belt sizers, you dont even need a belt if they have one, just set the scale up to 90" for a 5/8 belt, and then just read what they have call for a 1/2" belt. | |
| ![Go down](https://2img.net/i/empty.gif) | | dwcopple Member
![If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | dwcopple Member
![If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? Empty](https://2img.net/i/empty.gif) | Subject: Re: If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? June 4th 2014, 9:07 pm | |
| - dwcopple wrote:
- well, they had one. Turns out what I had was a B90=5L930=93" not 90". It said I need a 4L920 or 92" 1/2" belt.
Good to see it work out for you. i had to get a belt and they were out of the 1/2" size and i almost bought a 5/8" of the same size, that wouldnt of worked. re measured, and got the correct 5/8 belt. | |
![If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | If a 90" 5/8 notched belt fits will a 90" 1/2 belt fit? | |
| Who is online? | In total there are 115 users online :: 0 Registered, 0 Hidden and 115 Guests
