 Brake idea, using existing brake.
TroyBilt Pony
FOSWMT
dked41
Murray modder
CornishMorgan
12 posters
Go to page : Previous  1, 2
FOSWMT
Brake idea, using existing brake. - Page 2 Empty
PostSubject: Re: Brake idea, using existing brake.   Brake idea, using existing brake. - Page 2 Icon_minitimeOctober 4th 2013, 12:07 pm
Would it be possible to see your bracket and the parts separately please as would like to have a go at making this .
k2500life wrote:
The rotor and caliper came off of a pocket rocket and I mounted the caliper by making an adapter plate using the original caliper mounting bolts and I tooled the original disc and bolted the new one up any more q's happy to answer them
Brake idea, using existing brake. - Page 2 Image88
Brake idea, using existing brake. - Page 2 Image89
Brake idea, using existing brake. - Page 2 Image90
http://www.friendsofspeckledwood.org.uk
PostSubject: Re: Brake idea, using existing brake.   Brake idea, using existing brake. - Page 2 Icon_minitimeOctober 4th 2013, 3:18 pm
Um I'll have to take it apart but ill see what I can do
http://www.lastdropgarage.com
CornShuck4CE
CornShuck4CE
PostSubject: Re: Brake idea, using existing brake.   Brake idea, using existing brake. - Page 2 Icon_minitimeApril 13th 2014, 12:26 am
I used old car brake shoes on a peerless mst 206 thay had about 1/8 inch break pad left on them cut the shoe down to size and whala insta better brakes works good still in it today and thats been about 8 months ago. Love the tandem axel chain idea. The factory caliper setup works great for me. The car breaks take alot more abuse and are made for the high speed braking. I made a hand brake from the deck lift componets of a murray widebody. And some dech ingagement linkeges. Works awsome. Good luck
B440
B440
PostSubject: Re: Brake idea, using existing brake.   Brake idea, using existing brake. - Page 2 Icon_minitimeApril 13th 2014, 8:44 am
Keeping the chain tight may be a problem. It would spin both directions, so you would need two spring-loaded tensioners. And you would be going around the front axle, so the sprocket would have to be large enough for the chain to clear the axle.
jonjunk
jonjunk
PostSubject: Re: Brake idea, using existing brake.   Brake idea, using existing brake. - Page 2 Icon_minitimeApril 13th 2014, 3:17 pm
I was hoping to do hydraulic brakes with my handlebar mod in the future! I already have the master cyl.
CornShuck4CE
CornShuck4CE
PostSubject: Re: Brake idea, using existing brake.   Brake idea, using existing brake. - Page 2 Icon_minitimeApril 13th 2014, 4:13 pm
I have the hydrolic brake componets off of a china made atv that i plan to put on my 820 1 inch axel shaft i plan on placing it on axel and biulding a mount transaxel or fram to mount it. Just need to lock it first so the brakes transfer to other side
» Trans Axle Input Shaft Brake (Pinion Brake)
» Peerless Brake Idea
» My brake setup
» Hand brake
» No brake assembly at all
All-Terrain Lawn Tractor Forum :: Technical Forum :: Drivetrain & Brake Tech :: Brake Support-
