| | Guys! Heellllllpppppp! I need brakes | |
Josh Blair Member
Age : 26 Join date : 2011-10-16 Points : 4756 Posts : 41 Location : Mt. Pleasant TN
| Subject: Guys! Heellllllpppppp! I need brakes November 28th 2011, 12:03 am | |
| Has anyone ever had trouble with brakes and couldn't adjust them? That is my problem. She is a craftsman lt 4000. How do you fix this? | |
Age : 53 Join date : 2010-02-10 Points : 7002 Posts : 1726 Location : Florida, USA
| Subject: Re: Guys! Heellllllpppppp! I need brakes November 28th 2011, 1:46 am | |
| Youll have to pull the wheel off, and take the brakes apart- the disimilar metals cause corrosion and seize up.
Once the caliper is off, set it flat on a level concrete surface- use a hammer ( yes a hammer) to pound the steel pins through - just hit the pins. Once the pins are out, sand and clean the steel pins, clean the caliper bores, use a tiny dab of never seize on them( where they pass thru the caliper) and the caliper bolts and reassemble it - that should keep the corrosion away. | |
| | | Josh Blair Member
| Subject: Re: Guys! Heellllllpppppp! I need brakes November 28th 2011, 4:54 am | |
| - dangeroustoys56 wrote:
- Youll have to pull the wheel off, and take the brakes apart- the disimilar metals cause corrosion and seize up.
Once the caliper is off, set it flat on a level concrete surface- use a hammer ( yes a hammer) to pound the steel pins through - just hit the pins. Once the pins are out, sand and clean the steel pins, clean the caliper bores, use a tiny dab of never seize on them( where they pass thru the caliper) and the caliper bolts and reassemble it - that should keep the corrosion away. She moves but I just can't stop | |
| | | gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5132 Posts : 392 Location : west chazy ny
| Subject: Re: Guys! Heellllllpppppp! I need brakes November 28th 2011, 11:23 am | |
| How long have u had it? do what he said but check the pads might be wore down or deteriorating. I had a tractor years ago when i took it apart the one side of the pad was gone it broke apart. | |
| | | Josh Blair Member
| Subject: Re: Guys! Heellllllpppppp! I need brakes November 30th 2011, 6:01 pm | |
| Well guys I took the caliPer off and the pins that engage the pad were rusted open so hammered them out and sprayed with Penetration oil put it back together and BRAKES!! | |
| | | gearheadmike Member
| | | | Sponsored content
| Who is online? | In total there are 19 users online :: 1 Registered, 0 Hidden and 18 Guests MightyRazeMost users ever online was 412 on January 7th 2023, 7:59 am |
