 removing pto clutch pulley and running mower
2 posters
DiGiacomo
DiGiacomo
removing pto clutch pulley and running mower Empty
PostSubject: removing pto clutch pulley and running mower   removing pto clutch pulley and running mower Icon_minitimeOctober 10th 2023, 11:46 pm
If i take the pto pulley off when i remove the deck, do i need to make a spacer for the shaft up to the drive pulley and tighten the shaft bolt to the spacer??
sounds like a dumb question...but I've seen a few of these drive pulleys being destroyed trying to get them to come off the shaft on a few u tube vids.
I am planning on using my blade quite a bit for  stuff besides pushing snow and I would feel better if it was on my bench instead of getting beat up under the deck.......
PostSubject: Re: removing pto clutch pulley and running mower   removing pto clutch pulley and running mower Icon_minitimeOctober 11th 2023, 8:40 pm
If the pto pulley in question is an electric clutch then chances are good you will indeed need a spacer of sorts, you might even be able to get away with a stack of washers large enough to go over the shaft.
Pictures are always super helpful to really see what's up.
My All Terrain Tractors:
DiGiacomo
DiGiacomo
PostSubject: Re: removing pto clutch pulley and running mower   removing pto clutch pulley and running mower Icon_minitimeOctober 11th 2023, 8:56 pm
thanks Brian, I went ahead and found a shorter bolt and ended up using one of my 1/2 in. drive sockets.....it worked great...........now my pto clutch can rest for the winter....while i push snow.........
» Lt4000 clutch/ pulley swap
» pulley swap and clutch help
» Clutch gets in way of a larger pulley
» Double pulley clutch
» Can you could put a centrifical clutch on a vertical shaft mower
