 pulley swap and clutch help
maxrpm1224
maxrpm1224
pulley swap and clutch help Empty
PostSubject: pulley swap and clutch help   pulley swap and clutch help Icon_minitimeJanuary 12th 2013, 12:19 am
i just did a front engine pulley swap an my 98murray so it has a 6in in the front and the stock 8in on the rear. so i also needed a bigger belt so i used the old mower deck belt cause it was fine. im using the stock single pulley clutch but want o add some tensioners any suggestions on how, were and what kind to mount?
Marines2621
Marines2621
PostSubject: Re: pulley swap and clutch help   pulley swap and clutch help Icon_minitimeJanuary 12th 2013, 1:06 am
Make a adjustable idler pulley v or flat kind pulley. U could also do a double pulley clutch. Like Fearlessfront's clutch design.
PostSubject: Re: pulley swap and clutch help   pulley swap and clutch help Icon_minitimeJanuary 12th 2013, 2:20 am
A double pulley clutch would help with your tension
» Lt4000 clutch/ pulley swap
» Clutch gets in way of a larger pulley
» Double pulley clutch
» removing pto clutch pulley and running mower
» Would you use a chain or pulley type clutch and what ratio?
