 Clutch gets in way of a larger pulley
muddybasilisk
muddybasilisk
Clutch gets in way of a larger pulley Empty
PostSubject: Clutch gets in way of a larger pulley   Clutch gets in way of a larger pulley Icon_minitimeMay 7th 2024, 8:23 pm
Right now my pulley swapped lt1000 gets about 16 mph. Not bad but I want it faster. Normally you’d do that by swapping the front pulley, but my clutch gets in the way when pushed fully down. Do y’all have any tips for making room for a bigger front pulley? Clutch gets in way of a larger pulley Img_2912
Clutch gets in way of a larger pulley Img_2914
Clutch gets in way of a larger pulley Img_2913
PostSubject: Re: Clutch gets in way of a larger pulley   Clutch gets in way of a larger pulley Icon_minitimeMay 7th 2024, 8:47 pm
Maybe build your own like a murray's on the transaxle side?
Clutch gets in way of a larger pulley Img_2692
Clutch gets in way of a larger pulley Sig115PROJECTS:
Clutch gets in way of a larger pulley Sig214Clutch gets in way of a larger pulley Sig314
muddybasilisk likes this post
PostSubject: Re: Clutch gets in way of a larger pulley   Clutch gets in way of a larger pulley Icon_minitimeMay 7th 2024, 10:16 pm
Maybe this will help? Mowron clutches work pretty good.
Budget_gokart
Budget_gokart
PostSubject: Re: Clutch gets in way of a larger pulley   Clutch gets in way of a larger pulley Icon_minitimeMay 8th 2024, 4:32 pm
You can turn everything around kinda ive got two LT1000 tractors and I'll post my clutch build in my buildoff post in detail
muddybasilisk
muddybasilisk
PostSubject: Re: Clutch gets in way of a larger pulley   Clutch gets in way of a larger pulley Icon_minitimeMay 10th 2024, 9:48 am
@Budget_gokart What do you mean turn it around? Did you swap it to the back or what
Budget_gokart
Budget_gokart
PostSubject: Re: Clutch gets in way of a larger pulley   Clutch gets in way of a larger pulley Icon_minitimeMay 12th 2024, 9:54 am
The whole assembly you should be able to take it off and flip it backwards and you have to cut and reweld the rod, it takes a bit of modification but it works and I'll show pictures if I can get some
» Double pulley clutch
» pulley swap and clutch help
» Lt4000 clutch/ pulley swap
» removing pto clutch pulley and running mower
» Would you use a chain or pulley type clutch and what ratio?
