 Can you could put a centrifical clutch on a vertical shaft mower
indianaboy93
Can you could put a centrifical clutch on a vertical shaft mower Empty
PostSubject: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 2nd 2010, 10:31 pm
i was just thinkin about this the other day. i was wondering if you could put a centrifical clutch on a vertical shaft mower and then run your belt back to the trani like you always would. would this work? (or am i just an idiot? lol)
PostSubject: Re: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 2nd 2010, 10:40 pm
Yeah it will work, northerntool sells them. cheers
indianaboy93
PostSubject: Re: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 2nd 2010, 10:43 pm
this is just a thought idk if i'd want to do it. me and my dad used to be really big into go-karts, thats what got me thinkin about it. might have one layin around.
arild365
arild365
PostSubject: Re: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 2nd 2010, 10:47 pm
i have a tranny that converts chain drive to belt (horizontal to vertical) or the other way around. it would work great for this kinda deal
indianaboy93
PostSubject: Re: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 2nd 2010, 10:49 pm
i was thinkin if you had one of the mowers that has the forward and reverse and then the gears seperate it could work. just use the forward and neutral part and put the centrifical clutch on the motor. and then run your belt back to it.
Webmaster
Webmaster
Webmaster
Webmaster
PostSubject: Re: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 4th 2010, 5:02 pm
It would work, there just expencive, tend to wear out, and don't like water... No It would make a fun street tractor though, which will probably be my next project.
http://ww.atltf.com
indianaboy93
PostSubject: Re: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 4th 2010, 5:26 pm
yea. i may never do this but it was just a random thought. i have them alot... lol
PostSubject: Re: Can you could put a centrifical clutch on a vertical shaft mower   Can you could put a centrifical clutch on a vertical shaft mower Icon_minitimeMay 4th 2010, 6:39 pm
Lawntractor racers use them - usually the chain driven types . I have one belt driven and one chain driven clutch- the chain one is going on the wizard - might use the belt one on the mild mod MTD- ill haveta see when i get back.
I dont think theyd work too well on offroad situations - wear out too fast.
» Vertical Shaft Engine on Horizontal Shaft Mower
» Vertical shaft go kart
» Vertical Shaft Diesel?
» removing pto clutch pulley and running mower
» Honda vertical shaft kart with peerless 700.
