 Vertical shaft go kart
CraftsmanKid1
CraftsmanKid1
Vertical shaft go kart Empty
PostSubject: Vertical shaft go kart   Vertical shaft go kart Icon_minitimeJuly 4th 2012, 12:41 pm
ok so heres my plan im going to be getting a go kart with a blown 5 hp motor an i have a craftsman with a good 5 spd manual trans and a 12.5 hp tecumseh thats a vertical shaft and im goin to take the go kart and mount the trans in the rear and the motor behind the seat and run either a pulley or take the pulleys off and put sprockets and run a chain(witch one do u guys think??)and put a shifter in to shift threw gears like a shifter kart i have a picture i made in paint so tell me what u guys think
https://s1152.photobucket.com/albums/p493/CraftsmanKid/go%20kart/
CornishMorgan
PostSubject: Re: Vertical shaft go kart   Vertical shaft go kart Icon_minitimeJuly 4th 2012, 1:42 pm
cool idea, a go kart like that with a 5 speed and 12 hp engine should be great fun. I'd put a centrifugal clutch on the engine and run a chain to the gearbox. I can't see why it wouldn't work and it would stop any chance of the belt slipping.
Hillbilly Homer
Hillbilly Homer
PostSubject: Re: Vertical shaft go kart   Vertical shaft go kart Icon_minitimeJuly 4th 2012, 1:51 pm
Chain and a Exclamation GOOD Exclamation centrifugal clutch and it will work fine.
Don't forget clutch and chain need to be maintained.
CraftsmanKid1
CraftsmanKid1
PostSubject: Re: Vertical shaft go kart   Vertical shaft go kart Icon_minitimeJuly 4th 2012, 3:11 pm
do i have to put a centrifugal clutch on it has neutral and reverse and all 5 spds im trying to do this really cheap and im allready paying 50 for the go kart....how much would one be?
Hillbilly Homer
Hillbilly Homer
PostSubject: Re: Vertical shaft go kart   Vertical shaft go kart Icon_minitimeJuly 4th 2012, 7:23 pm
With a chain you will need a clutch.
If you are going for cheep use a belt drive.
Pulley And Belt Calculator http://www.csgnetwork.com/pulleybeltcalc.html
» Honda vertical shaft kart with peerless 700.
» Vertical Shaft Engine on Horizontal Shaft Mower
» Vertical Shaft Diesel?
» How To: PTO Winch for Vertical Shaft Engines
» Can you could put a centrifical clutch on a vertical shaft mower
