 [Finalist][2020 Build-Off Entry] darkside's hot rod pick up
loggers gogert
Hillbilly Offroading
darkside0914
10 posters
Go to page : Previous  1, 2, 3, 4, 5
darkside0914
2020 Build-Off Top 3 Winner
[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Empty
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 2nd 2021, 11:34 am
@Rustbucket Garage black for the block since i already have high temp black paint, haven't decided on the color of the tins, but will likely be body color when i get to that point, haven't decided on that either, but it's not staying all black
here's the pics of the insides of the oppy the cylinders are going to need some cleaning but otherwise not bad
[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 DSCN0243
[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 DSCN0239
[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 DSCN0241
[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 DSCN0240
darkside0914
darkside0914
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 8th 2021, 1:41 pm
well this stinks, i just realized i put the bottom crank seal in upside down, wasn't paying as close attention as i should have been, so now i have to remove the pan, pop the seal back out, hopefully not damaging it in the process, and reassemble everything putting the seal in the right way
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 8th 2021, 4:42 pm
That sounds frustrating!
My 2055 I still haven’t figured out what the small spring on the butterfly control arm goes to lol!. Runs, but it idles slower. Hope it all works well for you
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 8th 2021, 5:22 pm
Yikes.  Take your time.  Hope it's a higher quality seal and not one of those a fraction of a millimeter smaller china ones.  Tell me how I know that one.  Silly seal spun with the crank.
[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Sig115PROJECTS:
[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Sig214[Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Sig314
darkside0914
darkside0914
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 8th 2021, 8:18 pm
i got it out with no damage, it fits tightly in the borei don't think it'll have any troubles, i had to tap it down with a hammer and small blunt punch to seat it fully so it should be just fine, next thing i need to do is temporarily mount it and get it cleaned, running, and ready to go into it's new home
darkside0914
darkside0914
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 8th 2021, 8:35 pm
@Rustbucket Garage are you referring to the long tiny spring that fits over the thin rod going from the governor to the carburetor, if so that's a anti surging spring more or less, it holds light tension on the rod so the butterfly doesn't move on it's own causing the rpm to change while running, it should go from a small hole in the arm where the rod connects to the carburetor and on the other end it should have a small hole in the governor arm where it connects there, as for idle being low there should be a screw with a spring that you can adjust to raise the idle, this screw just acts as a stop for the butterfly, it'll be at the top of the carb or where ever the arm that controls the butterfly is located on your engine, if it's not running at full rpm when at full throttle you may need to adjust your throttle cable itself, or the governor, of course all this depends on the engine too
Rustbucket Garage
Rustbucket Garage
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 8th 2021, 8:57 pm
Thanks for the advice! I’m pretty new to the small engine world (this is my first GT) and I have the spare parts mentality sometimes and I put something back together and hey, spare parts! Hope it didn’t need that lol. I will get that spring hooked up soon, it sounds like that is exactly the culprit because it backfires when it is idled down too quickly. Thanks again. Means a lot to me!
Can’t wait to see the oppy mounted! [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 2731072446
darkside0914
darkside0914
PostSubject: Re: [Finalist][2020 Build-Off Entry] darkside's hot rod pick up   [Finalist][2020 Build-Off Entry] darkside's hot rod pick up - Page 5 Icon_minitimeFebruary 8th 2021, 10:12 pm
@Rustbucket Garage no problem, hope it helps with your issues, and depending on how things go, it might end up with that kohler magnum off the yard pro instead
Page 5 of 5Go to page : Previous  1, 2, 3, 4, 5
» Hillbilly Offroading's "Mud Stompin Wards" Montgomery Ward Mud Mower [2020 Build-Off Entry] [Finalist] [Winner]
» [DNF][2020 Build-Off Entry] loggers gogert build off entry !!!!
» Mightyraze's "Sasquatch II" [2017 Build-Off Entry] [Finalist]
» [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry]
» [DNF][2020 Build-Off Entry] Mini Back yard basher build
