| Haspin 2020! June 10th - 14th | |
+8mr.modified Creepycrawler Doug Mtdmudmower Murraymountain CraftsmanQuad19 redzz02 TheRainbowBoxer 12 posters |
| Subject: Re: Haspin 2020! June 10th - 14th February 19th 2020, 6:27 pm | |
| I just now got that the motorhome was mister modifieds. I thought it was mighty haha. I need to read closer lol | |
Age : 34 Join date : 2013-11-02 Points : 7163 Posts : 2910 Location : New Jersey USA
| Subject: Re: Haspin 2020! June 10th - 14th February 19th 2020, 8:37 pm | |
| I thought there may have been a discrepancy. I do that too sometimes.
I'm actually not too worried about it breaking down. Engine sounds good. With a new carb and set of points, should be mostly good to go. I'll bring some repair items along. The carb is pretty messed up and worn out so I'll just replace it. Main thing I would worry about is the transmission giving up along the way. But it hasn't sat for a really long period of time without being run over the years so hopefully that will have been a help. I'll give it a test run once it's road legal again and see how it feels. If it's really needed, I can pull the trans out and get it rebuilt.
Once the back end is braced back up a little, I'll buy a set of trailer tail lights and wire them back up. The stock ones were kind of one off deals and the sun baked them. Pretty much they fell apart. It shouldn't take much to brace the body back up. Even though it's pretty rough, I think it would still take a lot to pull it off the frame. Even if it did fall apart, that wouldn't really effect the trip all that much. I could just ratchet strap it together.
The water system was pretty much a wreck so I gutted all the copper pipes. Left the drain system in place though. I saved the 12 volt pump so I might be able to rig up something to the sinks and maybe even the shower if I feel like getting fancy. We'll see how it goes.
Gonna do some custom ATLTF lettering on the hood for sure. Don't know about the sides yet but maybe. I'm thinking rustoleum and brush job outta do it. | |
Age : 24 Join date : 2016-04-12 Points : 5975 Posts : 2645 Location : Indiana
| Subject: Re: Haspin 2020! June 10th - 14th February 20th 2020, 8:13 pm | |
| I’ve been bit by the haspin bug. All of a sudden I’m super amped up to go. I want to get reverse back on the mk2, get the trans breather done, rack and pinion steering done, charging system put on the engine, and get a hood mounted. All of that together shouldn’t take me too long. I’ve got two buddies that might be on board to go. Really trying hard to get as many friends to go as I can | |
| Subject: Re: Haspin 2020! June 10th - 14th February 21st 2020, 2:21 pm | |
| I was gonna make a super Haspin tractor meet promo vid, but my old beat computer is kinda slow these days and I'm too cheap and lazy to go buy another one since I really don't use it that often. Not only that, but time is at a premium at simplicity racing with the new build and RV renovating going on.
Hopefully we get a bunch of people showing up this year, that would be pretty neat. This should be the year to go if your on the fence! | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5695 Posts : 1091 Location : Galion, OH
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6370 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Re: Haspin 2020! June 10th - 14th February 24th 2020, 3:31 pm | |
| No idea on colors yet.
Previously, we have used Yellow, bright green, forest green, black, white, grey, royal blue, and Red.
Taking suggestions. | |
| Subject: Re: Haspin 2020! June 10th - 14th February 24th 2020, 6:35 pm | |
| Desert tan or OD green? Battleship grey? Military colors would be cool since we’re going with the steel soldiers | |
| Subject: Re: Haspin 2020! June 10th - 14th February 24th 2020, 7:47 pm | |
| Shirt design looks good to me. Guess you guys are almost out of different color options. Simplicity orange it is then. | |
redzz02 Site VIP
Murraymountain Veteran Member
Join date : 2019-02-04 Points : 4426 Posts : 2178 Location : North Carolina
Age : 49 Join date : 2016-09-06 Points : 15653 Posts : 10975 Location : Oklahoma
| Subject: Re: Haspin 2020! June 10th - 14th May 1st 2020, 10:41 pm | |
| Well this sux... We were planning on making it up again this year, but found out today due to Covid, my wife's parents plans got shifted. They are going to a memorial in Utah and will be gone most of the month of June. We are the only ones that can/will take care of their animals. So I am out. | |
| Subject: Re: Haspin 2020! June 10th - 14th May 7th 2020, 10:43 am | |
| I have been wondering, assuming that Haspin is open again for the normal dates and things go according to original schedule, How many people are still planning on going. I figured with some people out of work and all that, priorities may have shifted slightly.
I'm on the fence a bit about going, still thinking about it though. | |
Age : 22 Join date : 2016-10-29 Points : 7208 Posts : 4013 Location : Lewisburg, KY
gimpyrobb Member
Join date : 2019-06-02 Points : 2052 Posts : 47 Location : Cincinnati Ohio
| Subject: Re: Haspin 2020! June 10th - 14th May 13th 2020, 10:47 am | |
| I'm pretty sure I'm going, got my approval number for June 10-14. Currently sorting out a reliable vehicle to haul everything out. For some reason that's every time I go out...
Can't get my super 1971 Ford RV registered with NJMC closed for CORONAVIRUS! So that's unfortunate. I have a back up plan though.
Too bad you can't make it out mightyraze! Maybe I'll catch you out there another time. | |
| Subject: Re: Haspin 2020! June 10th - 14th May 13th 2020, 12:17 pm | |
| Yeah, I was a no go earlier this year, then as the year (pre covid) started looking great for coming then covid and other things happened and killed that opportunity. No chance now to come. | |
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5695 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Haspin 2020! June 10th - 14th May 13th 2020, 9:56 pm | |
- I'll go if someone wanted to swing down to KY and pick me and a tractor up lol
If you weren't 4 hours south west of laurel IN, I wouldn't have an issue with it. Your a bit outta the way on my run. | |
Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7776 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: Haspin 2020! June 10th - 14th May 13th 2020, 10:08 pm | |
Pay my fuel and mayyybeee - gimpyrobb wrote:
- Do we have a buy sell trade thread for Haspin, or is this it?
I can make one if there is interest. Totally forgot about it this year. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Haspin 2020! June 10th - 14th May 14th 2020, 9:50 am | |
| Okay, well pretty sure I won't be there. One of the puppy buyers pick up the last pup on the 6th, and I'm going to Rockcrusher Farm on the 7th. 3 days in between is just not enough time. | |
