 [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]
George Gooding
RockeyDA
tinkering bob
SteamNut247
swampduck03
19 posters
Go to page : Previous  1 ... 6, 7, 8 ... 12 ... 17  Next
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Empty
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:23 pm
Yeah I'd have a machine shop do it or get a dremel tool or something, it'd really suck to mess it up.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:26 pm
Yeah, pull the crank out and have a shop put one in with a 3/16" end mill, a lot better off that way.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:30 pm
Yeah man, if you do it right you won't regret it later. [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 2731072446
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:32 pm
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Downlo15
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:34 pm
Uh, we're talking about the engine going into the tractor you're building in this thread, I don't see how that's thread jacking. Also, we're just trying to help you out here..
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:35 pm
We're still talking about this tractor, not some other random stuff.
So are you gonna do it right or mickey mouse it?
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:36 pm
I know but ya'll have reiterated yourselves many a time. I get your points, okay? Smile
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:37 pm
This is what he's going to do with it Razz Very Happy
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 W_dies10
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 1st 2018, 4:40 pm
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Matt_c10
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 3rd 2018, 1:49 pm
you know, if you took a dremel and stacked a few cut off wheels together you cold probboly cut a decent key way, wold make test it on some junk shaft or something Chinese first.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 3rd 2018, 4:39 pm
That's a good idea.  Practice on some scrap metal.  You could grind the keyway close like he suggests and then take your time filing it to perfection.
There is a way to do this since you already have a straight section of crankshaft to work with:
1)get the pulley hub where it needs to be
2) with the setscrews removed mark their locations on the crankshaft
3) spot drill a couple of dimples for the setscrews to dig down into.
The key thing here is to make sure you have the hub location correct the first time because it's not going to be as easy to move it.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 8:42 am
i wold be worreid about heat from welding warping the shaft. id personally cut my own keyway, plus what if he decides he wants to change is pully size later? always gotta leave room for change!
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 10:19 am
100% agreed, but unless you have the tools or know a guy its easier said than done.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 1:44 pm
posting this becase i think Double W Cross Ranch wold find this craigslist post interesting
its out of my price range but looks quite similar to his john deere even though its a slightly different model.
https://pennstate.craigslist.org/grd/d/john-deere-112/6629854929.html
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 6:25 pm
Possibly, but I don't own a dremel.
That was my backup plan.
SebastianAlbrecht wrote:
W, I would try to get a free blown Generator, and cut off the generator the tapered end, and try if it fits your Diesel tapered shaft and if it fits, weld the pulley on the tapered part of the generator, and cut off the generator crap you do'nt need
Unfortunately, that won't work as the pulley needs to be pretty far up the shaft to be aligned.
Yeah, cuz I might change the gearing of it.
Machining the tapered shaft end to 1" and cut a keyway in there, so it should be the best solution in my eyes
Yeah but I'd have to pull the whole shaft out and take it to a machine shop to do that.
I have neither.
That's super cool. A little overpriced for what it is in my opinion.
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 6:34 pm
@Double W Cross Ranch
if i were you i wold keep you eyes peeld for a cheep dremel, not to long ago i got one on sale at tractor supply for 20$. the basic single speed 35,000 rpm tool and some cut off wheels should be all you need
cheepest name brand i cold find used on ebay
https://www.ebay.com/itm/Dremel-MultiPro-Single-Speed-30-000-rpm-Model-275-Type-5-Corded/253718181422?hash=item3b12c8362e:g:tRUAAOSwmSZbNaTj
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 6:37 pm
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 6:38 pm
i used 2 of thoes disk stack together to cut the slit for the E clip in my axle shaft.
George Gooding
Just stay awake from Chicago electric dremmals from harbor freight, they are complete junk, but the accessories aren't too bad though
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 7:43 pm
Paint time!  @AllisKidD21 Yes I bought a more accurate JD green, lol.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 20180715
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 20180714
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 20180713
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 20180716
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 20180718
I think that the grille looks better yellow although it was black stock.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 20180717
Here's the notorious crankshaft.
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 20180719
And here are the fenders, sitting outside in the rain.  Didn't get to them today because they are wet.
Lemme know what you think!
RockeyDA
RockeyDA
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 8:03 pm
AWWW, that yellow on the grill looks slick, maby you can sneek some yellow on other small parts?
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 8:17 pm
HAHA...
I would have probably painted like a patio series deer.  Those are so cool!
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Custom10
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Sig115PROJECTS:
[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Sig214[Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Sig314
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 8:19 pm
Yeah those Patio Series are pretty neat, really rare though.
PostSubject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]    [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry]  - Page 7 Icon_minitimeJuly 4th 2018, 8:32 pm
RockeyDA wrote:
AWWW, that yellow on the fender looks slick, maybe you can sneak some yellow on other small parts?
I'm not sure what you mean @RockeyDA?  Did you mean the grille?  I plan to paint the pedal, the rims, the vari-drive handle, the engine pulley, etc. yellow.  Should look cool.
MightyRaze wrote:
HAHA...
I would have probably painted like a patio series deere.  Those are so cool!
Hmm...not my style really.  Anyway, I like the classic John Deere look.
Yeah, I'd never seen them before.
Page 7 of 17Go to page : Previous  1 ... 6, 7, 8 ... 12 ... 17  Next
» Rays customs. Build name Oh Deere [2018 Build-Off Entry]
» [Complete] Bow Tie Mud Guy : BOUNTY HUNTER BUILD [2018 Build-Off Entry]
» [Complete] Redzz02's Haspin Build [2018 Build-Off Entry]
» [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry]
» [Complete] Highboy77's DIESEL CRAFTSMAN! [2018 Build-Off Entry]
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2018 Archive :: Finalist Archive-
