| [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] | |
+15MightyRaze muckmudd George Gooding Double W Cross Ranch RockeyDA RichieRichOverdrive tinkering bob SteamNut247 TheBeal mr.modified biggasmowers CraftsmanQuad19 MatthewD swampduck03 AllisKidD21 19 posters |
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] July 25th 2018, 2:41 pm | |
| OUCH!!!!!!
Looks like water were in there. You should take the Engine apart again, take out the piston, and hone the cylinder. Then remove all the buildup with a wire wheel, lap tha valves, put everything together, remove the rust off everything before reassembling it, check the injection stuff, if everything works correct, and lube up the cylinder, try to fire it up again! | |
Age : 23 Join date : 2018-02-27 Points : 3843 Posts : 1299
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] July 25th 2018, 2:56 pm | |
- Bet that kohler doesn't look so bad now, eh?
Oh the Krahper would need soooo much more, and be way less powerful. - SebastianAlbrecht wrote:
- OUCH!!!!!!
Looks like water were in there. You should take the Engine apart again, take out the piston, and hone the cylinder. Then remove all the buildup with a wire wheel, lap tha valves, put everything together, remove the rust off everything before reassembling it, check the injection stuff, if everything works correct, and lube up the cylinder, try to fire it up again! Yeah I guess that's the plan. - RichieRichOverdrive wrote:
- Personally i find it hilarious.
You have a strange taste of jokes. - RichieRichOverdrive wrote:
- So W, what now?
I guess fix it. I'm too stubborn to go back to that Krahper. | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] July 25th 2018, 3:32 pm | |
| Oh dear. Must have sat outside for a while. I wouldn't take the piston out, try rubbing the cylinder with very fine emery cloth to get rid of the rust and clean the carbon off everything first to see if it starts. Try using a blow torch in the air intake when you try to start it, should help ignite the diesel. Clean out the injectors too.
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] July 25th 2018, 3:47 pm | |
| No I would definitely take the piston out. Might as well hone the cylinder evenly and get a nice even crosshatching on the entire cylinder wall, then it'd be like starting with a brand new engine. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] July 26th 2018, 5:40 pm | |
| - Crazy_Carl wrote:
- I think that water damage should actually clean up pretty well. I'm still pondering what might be going on with the injection system as to why it didn't start. You might want to dissassemble or troubleshoot that too.
He did say that it was spitting diesel out of the exhaust, so I assume the injector is working. You can buy an injector for these engines for cheap if you need to. If it's putting diesel out the exhaust that means it's not being ignited, so using a blow torch as I said earlier would help to ignite the fuel. Possibly didn't ignite because of the rust/water in the combustion chamber preventing the fuel to burn. Or the compression isn't good enough to ignite the fuel by compression ignition.
RockeyDA Established Member
Age : 30 Join date : 2017-10-15 Points : 3257 Posts : 639 Location : Bellefonte PA
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] July 27th 2018, 6:33 pm | |
| Cross-hatching plays a big part in cylinder and piston lubrication. Basically a good hone job would make it like starting eith a brand new engine. I doubt that cylinder is the reason it's not starting though, maybe warming the air up like Matt said would help 'er out. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] July 31st 2018, 10:11 pm | |
| - MightyRaze wrote:
- The water damage sux man. Doesn't look too bad. Keep up the determination, get it cleaned up (honing, etc..) and try again!
I don't think it was the injectors, it was probably the standing water in the cup of the piston. - RichieRichOverdrive wrote:
- He should just put a p7100 in it lol
- MightyRaze wrote:
- Play nice.
Hear that rich!!! - Crazy_Carl wrote:
- Does sound like a compression problem.
What were the valves lashed at? A guestimate, I couldn't find specs on it. Tore it down tonight. I bet I have the ONLY 7 horse Yanmar with DIRT in he bottom of the crank case. Must have gotten in where the drain plugs weren't. Well, I guess I'll do some valve work and hone the cylinder, reassemble it, and try again. | |
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] August 1st 2018, 12:18 pm | |
| - MightyRaze wrote:
- Double W Cross Ranch wrote:
- Well, I guess I'll do some valve work and hone the cylinder, reassemble it, and try again.
Couldn't see the piston well. How were the rings?
Really good, surprisingly. - SebastianAlbrecht wrote:
- Yep! The Yanmar needs to be rebuilt!
I wish I could help you there, but I spent my last money on Murray Widebody.
LOL thanks but I can afford it. I have enough money, I'm just a stingy old miser. lol | |
| Subject: Re: [Complete] John Deere 110 "Sub-Compact Tractor" Build [2018 Build-Off Entry] August 2nd 2018, 5:03 pm | |
| - MightyRaze wrote:
- Good deal, should be able to clean it up nicely.
Yup! - RockeyDA wrote:
- gotta get er going before these flood rains stop. you wet down in texis? i wold be really bad off if i did not live on a summit.
Heck no, it's dry as a bone down here. All the creeks have dried up, no rain for months, the grass is all dead, starting to lose a few trees. Got the engine torn apart: Will have to order some parts, then I'll get it all together again. Also need to buy a torque wrench. | |
