| free field and brush mower | |
tinkering bob Member
| Subject: free field and brush mower May 6th 2018, 10:07 pm | |
| Picked a field and brush mower out of the garbage of all places I think it's an older Yazoo mower i'm thinking on ripping the briggs off of it and putting one of my old kohlers on it any thoughts ideas or experience with the brands? will post a photo or three when time permits
| Subject: Re: free field and brush mower May 6th 2018, 10:19 pm | |
| Bob! Good to see you finally got a thread made up. Hahaha. Yeah I say swap that K181 on there, she'd work pretty good. Looking forward to seeing some pictures of this unit. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: free field and brush mower May 6th 2018, 11:21 pm | |
| only trick with getting the 181 to work is going to be building a throttle setup for it have to figure out some sort of method for governing the speed any ideas? | |
Crazy_Carl Veteran Member
| Subject: Re: free field and brush mower May 7th 2018, 9:08 am | |
| Yes and no the k181 came off an air compressor so the throttle tends to hold ad wide wide open while the engine is off the way the throttle control was set up was it had a tube that bled air off the compressor tank and had basically a brass button that it would push that would push on the governor arm to steadily idle it down as air pressure built | |
| Subject: Re: free field and brush mower May 7th 2018, 10:18 am | |
| Interesting sounding throttle setup. Do you have a picture of it? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5489 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: free field and brush mower May 7th 2018, 4:57 pm | |
| Huh, that's a really neat looking setup! Well you might be able to take all the pneumatic stuff off of it and setup a hand throttle hooked to the governor arm. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: free field and brush mower May 7th 2018, 6:28 pm | |
| Cool machine! Does the belt twist from the engine to the deck? That's an interesting throttle setup on the Kohler, pretty unique. | |
| Subject: Re: free field and brush mower May 7th 2018, 7:36 pm | |
| I think all you're missing here is the spring that wraps around the governor shaft and maybe the plate that rotates on the governor shaft that the throttle connects to. Then you'd have to make a throttle linkage. | |
| Subject: Re: free field and brush mower May 7th 2018, 10:35 pm | |
| i'll probably wind up stealing the linkage off my 301 and doing something a bit less tame with that when the money comes in. for now i'm going to look into another way to get the flywheel off check the set of the coil gap from the flywheel and put some new points in it and carl your motor is cleaner than any of mine ever dreamed of being and yes it's a twist belt setup this is one of those machines that seems to have been made with pure simplicity in mind. | |
| Subject: Re: free field and brush mower May 11th 2018, 7:25 am | |
| Metal wheels like the Amish have? neat, Due to the lack of shock absorption with the rubber tires, it does cause things to crack and fail on their machines.
The K301 had a magneto style ignition and not the 12volt automotive style ignition either? | |
| Subject: Re: free field and brush mower May 11th 2018, 10:18 pm | |
| yep 2 kohlers 2 mags no auto style ignition though that may change soon if I get any sort of inspiration. and it's a walk behind brush/field mower so I don't think breakage will be much issue nice soft field dirt and swamp dirt and all that. and I got the motor on there but I need to weld on a belt guide so it quits throwing them had to drill new holes in the frame as the kohler has a completely different bolt pattern than the briggs does and the pto is positioned different at least it's almost operable if I can get it to stop throwing belts I think i'll be set. | |
Age : 22 Join date : 2016-10-29 Points : 7212 Posts : 4014 Location : Lewisburg, KY
| Subject: Re: free field and brush mower May 11th 2018, 11:53 pm | |
| with some luck I can use mine to make money cause buying them new is expensive so maybe people will find it cheaper and easier to use me instead | |
| Subject: Re: free field and brush mower May 12th 2018, 12:04 am | |
| Nice Bob! I love that old school muffler, haha. Same style one that's on my K160. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: free field and brush mower May 12th 2018, 12:08 am | |
| it works pretty well but it blows back towards my legs then rolls up my body and right up my nose not a big deal as I smoke from time to time but sometimes the gas fumes get to ya lol | |
| Subject: Re: free field and brush mower May 18th 2018, 12:14 am | |
| well the magneto quit (most likely any way) so supposedly the new one will be here some time tomorrow and with a bit o luck she'll run like a top again and maybe this time i'll remember to correct the blade direction (it's still backwards and upside down from the previous owner) | |
| Subject: Re: free field and brush mower May 21st 2018, 12:42 pm | |
| magneto came in right on time got it put on the mag plate now i'm just waiting for the rain to stop so I can put the new mag in | |
| Subject: Re: free field and brush mower May 21st 2018, 12:54 pm | |
| Sweet deal Bob! She should be running tip top for quite some time now. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
