 brush guard
WellThatsSurprising
Tractor Man Jeff
goesman
8 posters
goesman
goesman
brush guard Empty
PostSubject: brush guard   brush guard Icon_minitimeSeptember 4th 2012, 9:48 pm
How many of you have built some sort of brush guard for the front of your ride. I am looking for ideas.
Thanks.
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 4th 2012, 10:42 pm
We built push bumpers front and back with a rollover hoop on the front to protect the engine/hood/lights. The bumpers were made from galvanized conduit that Stretch had lying around. We bent the hoops using a hydraulic conduit bender. Bumpers were assembled and attached using a MIG welder. They were pressed into service a few times at Haspin this past summer.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Tractor Man Jeff
Tractor Man Jeff
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 5th 2012, 6:45 am
I need to make one for my tractor yet. Got some of the metal picked out. Still wondering what would look good.
WellThatsSurprising
WellThatsSurprising
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 5th 2012, 12:20 pm
I used an old pair of bmx handlebars and some angle iron, there's a pic of it in my build thread.
Junkstarbuilds
Junkstarbuilds
brush guard Empty
PostSubject: Same here...   brush guard Icon_minitimeSeptember 5th 2012, 2:14 pm
Inverted BMX handle bars are decent..I typically use what ever metal tubing I can find at the local dump site..
As for design I try and keep a spot centered and high, not necessarily for roll over but as a handle to give a good pull on..
I mostly look at atv and utv premades and copy to fit..
Cool idea on that roll over bar type..
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 5th 2012, 2:36 pm
As you mentioned, it gives a good grab bar to lift the front out of the mud or whatever. Our rear bumpers are also set a bit higher so that the roll bar hits the rear bumper when we are pushing someone back to camp.
Chaos Build
Haspin 2021 thread
goesman
goesman
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 17th 2012, 5:59 pm
Finally got around to building me a brush guard. Did I get a bit carried away. I still have some other ideas to add to it.
brush guard Aa7c3885
brush guard Fc16fa6b
And yes there is a winch hiding behind there.
Tractor Man Jeff
Tractor Man Jeff
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 17th 2012, 9:23 pm
No way. That is perfect. You can rest assured, with that thing on, your engine will be safe in a roll over. Now you need to build something like that for the drivers seat.
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 18th 2012, 11:07 am
That's freaking funny.... No problems hitting anything with that!
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 18th 2012, 11:26 am
I think we need to add one of those to Chris's tractor LOL!
Chaos Build
Haspin 2021 thread
TennesseeCowboy
TennesseeCowboy
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 18th 2012, 5:13 pm
Wow thats beefy looking!! Do you have any pics with the hood on?
goesman
goesman
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 18th 2012, 7:43 pm
Don't have a hood. I am going to put some sheet aluminum on the top tubes covering the motor some what. Thanks guys I'm still working on it. I am in the process of makeing some nerf bars also. Who knows how crazy this could get.
goesman
goesman
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 21st 2012, 7:05 pm
I managed to get some more work done today. All the angles were pain to get figured out. I am thinking about ditching the running boards and welding on some of the same metal I used for the front.
brush guard IMG_20120921_172952_zpsfea9d6aa
brush guard IMG_20120921_173005_zpse41960d9
brush guard IMG_20120921_173032_zps27d7689c
Tractor Man Jeff
Tractor Man Jeff
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 21st 2012, 9:54 pm
I wouldn't. That looks great. Nice job.
Junkstarbuilds
Junkstarbuilds
brush guard Empty
PostSubject: Im diggin it   brush guard Icon_minitimeSeptember 21st 2012, 10:28 pm
I like those side pipes.. And the front cage! Looks tough! pirat
What kind of precaution you doing for that Galvie Question Ive been thinking of using it alot more since it is so cheap to buy. I usually just run a llight fan (if inside) or weld outside and hold my breath silent I can get 3/4 inch stick of 8ft for 2$ which I will be using for a gear rack on the back of my trail boss..
goesman
goesman
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 21st 2012, 11:04 pm
Thanks guys. I really haven't done any thing about the galvanize yet. So far things are just tacked together. I usually just weld it but I think I might grind it first. I'm going to paint it any way. So far I only have one side done, I am hoping to get the done tomorrow along with finishing the electric start.
Junkstarbuilds
Junkstarbuilds
brush guard Empty
PostSubject: Issues with galvie   brush guard Icon_minitimeSeptember 21st 2012, 11:15 pm
I had noticed on the photo that white dust, which is from welding galvie..Well, I was making sure you are making some effort not to breath in the smoke from gavanized steel being vaporized (produces Zinc Oxide) which when inhaled in the nose and disolves into the blood in high concentrations "can" make you feel sick with several symtoms..all dependant on how much is involved...Wont kill you, but you wont feel good..
I just wanted to see if you had any special technique to avoid inhalation...I been thinking of making a breathing apparatise but I have yet to get sick, and I rarely weld it..but I plan on it in the future..
Tractor Man Jeff
Tractor Man Jeff
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 22nd 2012, 7:50 am
Just make sure your outside, and have a good breeze. If no breeze, use a fan. If I was around a good amount of smoke, I'd hold my breath until I completed the weld, which was pretty short.
Bgibby17
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 24th 2012, 12:29 am
one trick about welding galvanized is that as long as your outside or have some form of breeze you'll be okay. holding your breath may be a bit overkill on it though lol im a certified welder and have had plenty of galvanized to weld on.. the main thing to worry about is when your welding on it just keep your head out of the smoke cloud coming off the steel and you'll be okay. and if you ever do get sick or feel like you arent feeling right and have welded on galvanized drink lots of milk. somethin about it will help stop thechemical that is inhaled i guess lol
Junkstarbuilds
Junkstarbuilds
brush guard Empty
PostSubject: Just making sure..   brush guard Icon_minitimeSeptember 24th 2012, 12:37 am
I have never felt the effects..dont want to..I have heard of the milk..I have also heard to drink it prior to is good too..
just as a reminder, a slight breeze can also blow away your gas shield...so remember that as well..
Bgibby17
brush guard Empty
PostSubject: Re: brush guard   brush guard Icon_minitimeSeptember 25th 2012, 4:25 pm
a slight breeze can blow away your shielding gas but if u are using flux core then you will be ok but i dont know what all of us are runnin lol i run flux cored because most of my welding is done outside anyways
brush guard Empty
brush guard
» BRUSH HOG?
» Homemade Brush cutter
» free field and brush mower
» ideas for a grill guard
» How i can make or buy a guard or cover for my belt?
All-Terrain Lawn Tractor Forum :: Technical Forum :: Chassis Modification :: Bumpers, Brush Guards and ATV Racks-
