| | nabbed a free mower/kart chassis from a neighbor... | |
dwcopple Member
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | dwcopple Member
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | Subject: Re: nabbed a free mower/kart chassis from a neighbor... July 13th 2014, 5:17 pm | |
| tires are hard rubber compound not pneumatic and this thing has zerks everywhere! steering, axle, jackshaft, pulley, hubs, wow! jackshaft sprocket is 11 tooth and the pulley is 5" OD. that tensioner was for a belt setup that was actuated by the rod that travels up front to a pedal on the left. ![nabbed a free mower/kart chassis from a neighbor... IMG_20140713_171954_889_zpsyxn9jgir](https://2img.net/h/i3.photobucket.com/albums/y74/DCopp/IMG_20140713_171954_889_zpsyxn9jgir.jpg) ![nabbed a free mower/kart chassis from a neighbor... IMG_20140713_172051_160_zpsdxtwjb9t](https://2img.net/h/i3.photobucket.com/albums/y74/DCopp/IMG_20140713_172051_160_zpsdxtwjb9t.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | Subject: Re: nabbed a free mower/kart chassis from a neighbor... July 13th 2014, 5:56 pm | |
| Looks like a huffy mini mower! Most of the mini mowers were made from the same company i imagine, because my mini mower chassis is pretty close, if not the same dimensions as huffys, and mine was branded Springfield. ![nabbed a free mower/kart chassis from a neighbor... 11872010](https://i.servimg.com/u/f39/18/18/82/33/11872010.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | LAWN MOWER MUDDER Established Member
![LAWN MOWER MUDDER](https://2img.net/u/2812/37/66/46/avatars/825-65.jpg)
Age : 23 Join date : 2013-04-08 Points : 5135 Posts : 913 Location : Central Pa
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | Subject: Re: nabbed a free mower/kart chassis from a neighbor... July 14th 2014, 12:00 pm | |
| - LAWN MOWER MUDDER wrote:
- Hey can you snap a picture of that ID tag under the seat?
I agree with red. That looks identical to a Huffy mini frame. That is a nifty jack-shaft setup! its not an ID tag, it's lubrication instructions Thanks for the ID fellas. Need to find a side shaft engine now. Looked at a Tec 2-smoke from a snowblower but they mount sideways and I think making a bottom engine mount would be a PITA... | |
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | Subject: Re: nabbed a free mower/kart chassis from a neighbor... July 15th 2014, 9:49 pm | |
| found a painted over decal on the ass end that says "model 5025"...off to google that. Some Chachi from Craigslist supposedly is bringing me a 5hp Briggs off a snow thrower for $30 on Thursday. Says it runs good. Had e-start and recoil. Says its a 5/8" keyed shaft so clutching should be simple. Anything ideas for making it have a throttle instead of a set speed? I will be losing the "steering wheel" and replacing it with an ATV steering stem and clamps and motorcycle handlebars with throttle and kill switch. It would also appear I'll be setting up a 4" drum and band brake on the rear left wheel outside of the frame rail. Should be able to throw this thing together for short $$$ if all goes as planned. Looks like I'll be placing an order with BMI or mfgsupply for an engine mount plate, brake stuff, and a clutch at the minimum right now. Anywhere else I should look for that stuff? Their prices seem pretty good to me. | |
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | mr.modified Veteran Member
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | Subject: Re: nabbed a free mower/kart chassis from a neighbor... September 16th 2015, 10:32 pm | |
| The mini I had was a Suburbanite. Pretty much the same frame. I think various companys made them over the years. I remember a 4 digit model number on mine too but I forget what it was. Looks good though. | |
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
![nabbed a free mower/kart chassis from a neighbor... Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | nabbed a free mower/kart chassis from a neighbor... | |
| Who is online? | In total there are 95 users online :: 0 Registered, 0 Hidden and 95 Guests
