| Homemade Brush cutter | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5152 Posts : 1068 Location : New jersey
| | | | B440 Member
Join date : 2014-01-22 Points : 4204 Posts : 226 Location : Thompson, CT
| Subject: Re: Homemade Brush cutter April 9th 2014, 2:53 pm | |
| I can't see the vid right now, but let me know how it works out. I'm going to do this to a mower I have, but I was thinking that the blade needs to be exposed more in order to cut small trees properly. | |
| Subject: Re: Homemade Brush cutter April 9th 2014, 3:54 pm | |
| - B440 wrote:
- I can't see the vid right now, but let me know how it works out. I'm going to do this to a mower I have, but I was thinking that the blade needs to be exposed more in order to cut small trees properly.
I'm going to be testing it soon. And i would expose more of the blade but the more of the deck you cut the weaker the mower deck frame is. So im going to leave mine the way it is. | |
| | | B440 Member
| Subject: Re: Homemade Brush cutter April 9th 2014, 7:24 pm | |
| You could brace it underneath with some flat stock steel. Just brace further back since you only need the front edge. | |
| | | | lincolnmaniac New Member
Age : 53 Join date : 2014-03-24 Points : 3915 Posts : 18 Location : Tremont Pa.
| Subject: Re: Homemade Brush cutter April 10th 2014, 12:27 pm | |
| any brush to try it on? was that a noisy recoil or do you have turkeys? | |
| Subject: Re: Homemade Brush cutter April 10th 2014, 12:32 pm | |
| We have turkeys lol And i need to wait there isn't to much brush or grass yet | |
| Subject: Re: Homemade Brush cutter April 10th 2014, 12:35 pm | |
| I did test it on a little tree it worked great you can tell by looking at the picture its dirty | |
| Subject: Re: Homemade Brush cutter April 10th 2014, 1:00 pm | |
| cool!
i saw a post on another forum where the guy cut out the entire front of a cub cadet deck, then mounted it on the front of the tractor. | |
| | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5717 Posts : 1402 Location : Central PA
| Subject: Re: Homemade Brush cutter April 10th 2014, 3:55 pm | |
| If you were to attach a comb type thing you might be able to get even better results. It will help separate the stuff... a little bit easier to cut instead of a big ole clump. | |
| Who is online? | In total there are 53 users online :: 0 Registered, 0 Hidden and 53 Guests
