 100$ Dation 16HP MTD 990 "Mud Train"
darkside0914
14 posters
Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
RockeyDA
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Empty
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 7th 2019, 9:25 pm
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 NbmJIFI
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 IkvEJAG
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 9twTv0R
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 DFCgc19
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 WpVYvO3
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 7qhFzZq
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 JMvE9y5
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 GLRMdw4
100$ Dation 16HP MTD 990 "Mud Train" - Page 8 4Yn1MIU
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 7th 2019, 9:33 pm
It's not valve related. When it was run low on oil for hours it probably wore the cylinder and it now has a little bit of piston slap, causing the knock. That's what the knock sounds like to me anyways.
This would also be why it's burning oil, because the cylinder is worn.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 7th 2019, 11:30 pm
SebastianAlbrecht wrote:
sending it means not to care about it & run it til death
check the valve guides fist, before buying new rings
it cant be valves, the knock happens every rotation.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 7th 2019, 11:32 pm
also... how do i tune the main jet on a fully adjustable carb? is there better way then feeling for bog on just dumping the go lever/cluch all the way?
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 8th 2019, 8:56 am
@RockeyDA Well it's needs to be tuned at full throttle. Problem is when the engine is under load the governor lets in more air which will lean it a tad. The best method I've found is to turn your carb to factory specs, tweak it by feel (I struggle with this), and then check your spark plug after a hard run to see if you're running rich or lean.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 8th 2019, 12:29 pm
sounds to hard, dont even know how a spark plug will tell me, think ima rig somthg up so i can play with it while driving and do a mountan climb, i can send it full bore trying to get up mountnittany
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 8th 2019, 1:17 pm
Well if it's rich the plug will be wet and sooty. If it's lean the plug will be white and ashy looking. Ideal is somewhere in the middle lol.
Here's a link with a nice chart:
https://www.tuningmatters.com/how-tos/beginners-guides/check-spark-plug-correct-carburetor-setting/
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 8th 2019, 2:22 pm
I think a tan colour indicates a nice clean burn. Black is rich, clean lean.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeApril 9th 2019, 7:46 am
well, if i go by color i need to take my fancy shmancy briggs 9$ spark plug out and put a normal one in.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeMay 26th 2019, 7:43 pm
got the blown up mud train on the trails agin, boi it needs some TLC. need rings and head gasket bad. any one got links?
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeMay 29th 2019, 9:11 am
really wish i could find a set of rings and new headgasket for this motor.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeMay 29th 2019, 12:27 pm
NO i dont think therees any other biggs im going to find to take rings from, the cilinder is so big i can put my fist in it.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeMay 30th 2019, 5:53 am
WTFH!!
Welp then U can just send it LOL
send it were? small eng shop?
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeJune 1st 2019, 9:31 pm
WTFH!!
Sending stuff means that U just run it til it blows up
so what? are you telling me to not put oil in it and destroy a motor that should be a cheepely saved motor? i mean theres no rod play and the wall looks pretty good, and i was able to save headgasket. if i could just find a new set of rings i would basicly have a new motor.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeJune 2nd 2019, 9:39 am
i dont think the 16hp briggs is going to have a big fail, i think its just going to keep loseing compression till its not derivable.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeJune 2nd 2019, 4:04 pm
Yeah, but you can damage the cylinder walls beyond repair this way. I think that you might have piston slap, and the longer you run it like that, the worse it gets and it's very expensive to repair.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeJune 5th 2019, 7:55 am
well no one has links for rigns, so might be SOL on ever fixing it.
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeJune 5th 2019, 8:01 am
Check out isavetractors.com, they have a $50 piston kit for the Briggs 320000 engines.
RockeyDA
RockeyDA
PostSubject: Re: 100$ Dation 16HP MTD 990 "Mud Train"   100$ Dation 16HP MTD 990 "Mud Train" - Page 8 Icon_minitimeJune 6th 2019, 6:10 am
thats a bit more than im willing to pay for a few metal rings. i thoght new rings would be more like 15$
Page 8 of 11Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
» 16hp Solenoid
» 16hp Kohler magnum
» Can i put the carb from the 16hp on my 11.5 for more power?
» 16hp twin carb?
» 1980 Murray 16hp offroader
