 Can i put the carb from the 16hp on my 11.5 for more power?
2 posters
killer4051
Can i put the carb from the 16hp on my 11.5 for more power? Empty
PostSubject: Can i put the carb from the 16hp on my 11.5 for more power?   Can i put the carb from the 16hp on my 11.5 for more power? Icon_minitimeJuly 24th 2011, 1:40 pm
ok i have 2 things one i just picked up a craftsmen II aka the big cube ones with the 16 v twin and it was left out side with the hood off and and the carb was off and the motor got water in it and froz over winter and i just got it for free and it did cracked the block so i put a 11.5 briggs on it and it has a bad carb witch is the only wrong with it. its my fav motor it means a lot to me seens it came off my first tractor and i seem to not kill it. but back to my ? if i can do it can i put the carb from the 16hp on my 11.5 for more power? i know its going to be alot of work but i got tools and a welder and thats all i will need. thank u for taking your time to read this should have pics soon
PostSubject: Re: Can i put the carb from the 16hp on my 11.5 for more power?   Can i put the carb from the 16hp on my 11.5 for more power? Icon_minitimeJuly 30th 2011, 7:32 am
Alot of racers use mikuni carbs off snowmobiles and motorcycles - so it should be possible- only problems are an adapter to mount it to the motor and linkage- youll need to be a lil creative.
Most likely for the linkage youll need a foot or hand throttle - but youd also be disabling the governer ( carb would need to be mounted up higher on the motor) which i dont suggest, unless the motor had been properly built for the higher revs ( IE billet flywheel and internals).
Id either save it for another twin you come across or look into a motorcycle/scooter type carb.
I bot a couple scooter carbs at a flea market for $15 each- sometime i plan on adapting one to a twin and one to a single cylender motor - just too many projects on my plate.
killer4051
PostSubject: Re: Can i put the carb from the 16hp on my 11.5 for more power?   Can i put the carb from the 16hp on my 11.5 for more power? Icon_minitimeAugust 3rd 2011, 9:07 pm
thanks i might just wait tell i get a twin and i know the feeling i got alot of projects too
» 16hp twin carb?
» Will it give me a lil more power if i take a 18 hp carb and put it on a 16 hp motor?
» 16hp opposed twin smoke
» 16hp Solenoid
» 16hp Kohler magnum
