 16hp opposed twin smoke
2 posters
offroadredneck
offroadredneck
16hp opposed twin smoke Empty
PostSubject: 16hp opposed twin smoke   16hp opposed twin smoke Icon_minitimeMarch 5th 2013, 11:04 pm
today i went and started my racing mower and after running it for a couple minutes i got off the seat and it died, which is normal but i left the key on and acople minutes later there was smoke coming from under my flywheele, and the 25amp fuse blew. every time i put a fuse in it blows. so i onhooked the stattor and then put a fuse in and it was fine. i checked the stattor output and i go 4volts then9 then 18, then none?
Chopperhed
Chopperhed
PostSubject: Re: 16hp opposed twin smoke   16hp opposed twin smoke Icon_minitimeMarch 5th 2013, 11:21 pm
You let the magic smoke out.
I'm guessing some thing crispy fried under the fly wheel, likely the stator.
» Briggs and Stratton 16hp opposed twin questions
» Opposed twin smoke coming out pcv and carb
» 16hp Briggs and Stratton opposed twin shaving the head
» 16hp twin carb?
» 16HP Briggs Opposed, One Cylinder Stays Cold Issue
